11-05-2008, 07:11 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: South "O"
| making stock rims into beadlocks
can someone tell me how to make the stock losi rims into beadlocks???
11-05-2008, 07:19 PM | #2 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
11-05-2008, 09:48 PM | #3 |
Pebble Pounder Join Date: Sep 2008 Location: B.C., Canada
11-06-2008, 11:38 AM | #4 |
Newbie Join Date: Jan 2007 Location: St.Louis
2 inch pvc pipe cut into 3/4 inch pieces. You might have to shave a little on the inside of the pipe cause it is a very snug fit. I pounded them onto the wheel using a hammer. Don't forget to drill holes into the sides of the pipe for air flow. These work great for beadlocks. I thought about using steel pipe for the added weight, another idea to consider.
11-06-2008, 05:51 PM | #5 |
11-06-2008, 08:05 PM | #6 |
11-06-2008, 08:16 PM | #7 |
Rock Stacker Join Date: Oct 2008 Location: US Army / Iraq
That steel pipe is a great idea, thanks, I bet I scould even scrounge some up around here...
11-06-2008, 10:21 PM | #8 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
11-07-2008, 05:39 PM | #9 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
I found an interesting thing out today with these stock wheels. If you plan to run RC4WD Outcroppers, they require no mods. The OC bead is wider, all it takes is removing the rings and old tires, mounting the new tires and bolting the rings back on. They hold plenty tight, I've cartwheeled the rig sideways down a hill a couple times now and not one lost bead, no spinning on the wheels either. I can't speak for the other RC4WD tires, but the OC's will be locked by the stock wheels and are great performers too.
