11-05-2008, 08:29 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| drive shafts backwards ?? noticed that the Drive shafts on my losi are back wards. :-( i have always ran the D-shafts on my 2.2 rigs with the grooved side toward the tyranny. this way the groves will not get chewed on the rocks and start to hang up & not slide very well !! i recommend that you turn them around !! right ?? |
11-05-2008, 08:34 PM | #2 |
Doing that will make the torquetwist go the other way......:-P:-P
Last edited by Tanis; 11-06-2008 at 09:14 AM. Reason: added smilie so as not confuse the noobs |
11-05-2008, 08:35 PM | #3 |
I run my shafts the same way, for the same reason you stated |
11-05-2008, 09:26 PM | #4 |
Quarry Creeper Join Date: Oct 2004 Location: Somewhere in the middle
Flopped mine also to save the splines
11-05-2008, 09:35 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: B.C., Canada
| uuuuh NO that would just make the drive shat splines closer to the tranny. just like ZORLAC said, cause otherwise the splines will get all mashed on the rocks = not slide in and out. i dont see how you thought that the driveshaft would change the torque if the motor....seeing as how only the direction of the motor affects the torque twist of the truck
11-05-2008, 09:44 PM | #6 |
no talent hack Join Date: Feb 2007 Location: Redwood City
hahahaha tanis is a newb hahahahaha
11-05-2008, 10:36 PM | #7 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
i flopped mine as well, saving splines=good |
11-06-2008, 09:13 AM | #8 | |
I didn't want to put a smilie after it and give it away:-P Of course it won't change the torquetwist You know it Nabil Edited post so people know I was kidding | |
11-06-2008, 10:07 AM | #9 |
| theres always one in the bunch !!! "Tanis" |
11-06-2008, 11:35 AM | #10 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
I dident even notice, I better save my splines then thanks for the heads up. I havent realy run my mini sence I got it just built it to a torcion and its been sitting cause of the crappy tires and lack of $$$ to mod it |
11-06-2008, 11:59 AM | #11 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
02-17-2009, 08:59 AM | #12 |
| thought i would bump this back up. still see a lot of rigs with the drive shafts back wards. turn them around , shave the splines |
02-17-2009, 09:12 AM | #13 |
Quarry Creeper Join Date: Dec 2005 Location: Mechanicsville, VA
Im thinking that the "lip" of the female end, if switched around like you guys are talking, would be more prone to getting hung on rocks and would not slide as well. Just a guess??? Jon |
02-17-2009, 09:16 AM | #14 | |
yes , but if the splines get chewed up , then drive shafts won't slide , the suspension will not work :-( | |
02-17-2009, 09:28 AM | #15 |
Oh I understand what you guys are saying...I was just guessing at the reason they come like that. I must say Ive beat the crap out of mine and they still work fine the way they came. No signs of major wear & they still work fine when the susp cycles. Think I might compromise and switch the front around just for the "smooth sliding" factor in the front as well... Jon |
02-17-2009, 10:05 AM | #16 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| I run mine swapped as well and have never had a problem. The lip of the female shaft should be up in the links. I have my shocks limited which brings down the ride height and effectively hides the female end of the shaft up in the links. |
02-17-2009, 01:59 PM | #17 |
Newbie Join Date: Jan 2009 Location: SLC, Utah
thanks for the heads up, I never even thought about that |
02-17-2009, 08:13 PM | #18 |
RCC Addict Join Date: Nov 2007 Location: BV
On monster trucks and such it's still a good idea to run the female end towards the trans/diff so that it can't fill up with sand and sh*t. I can't imagine that being a real problem with a crawler, so female towards the axle is a good idea.
02-17-2009, 10:38 PM | #19 |
RCC Addict Join Date: Mar 2008 Location: SSF
I like both sides covered. |
