11-05-2008, 08:55 PM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
| Another Stock Rims Into Beadlocks How To
So, my new Mini Rock Bashers arrived and after reading this thread: 1.9 Beadlock conversion, so easy it's stupid I headed down to Home Depot eager to pick up some 2" pipe. I was standing there in the aisle looking at these huge 10' sticks of pipe wondering how I was going to get nice even narrow sections from it. I don't have a band saw or a chop saw and I can't cut straight with a hacksaw. So I was just wandering around the store thinking about it when I found some conduit adapters that fit tightly over the wheel. I figured that these had a nice square edge and I should be able to get a clean cut on them with a cut off wheel mounted in the drill press. So I shelled out $1.09 x 4 to make a set of bead locks. Kind of expensive compared to the $3.97 10' stick of pipe, but a lot easier to work with. I found these on the electrical conduit fitting aisle of Home Depot. They are called 2" box adapters. They fit nice and snug over the wheel just as they come. I cut them 18mm wide and used a deburring tool to put a slight chamfer on the inside and outside edges of the plastic ring. I also drilled a couple of 1/8" holes in the ring so that the tire can breathe. They hold tight and aren't cutting into the tire at all. Not my idea, just a different execution of an old idea. Hope it helps someone out. Some pics: Last edited by toybuilder; 11-05-2008 at 09:21 PM. |
11-05-2008, 09:23 PM | #2 |
Quarry Creeper Join Date: Oct 2004 Location: Somewhere in the middle
Like the idea of using pipe easy, cheap, and simple
11-05-2008, 09:43 PM | #3 |
You got them made! Looks great. Can't wait to check them out.
11-05-2008, 09:53 PM | #4 |
Pebble Pounder Join Date: Sep 2008 Location: B.C., Canada
the only thing it that there is little room for lead weights then.... and make sure that u take the sharp edges off of the faux(now real) lock rings as well as the adapters u are using...other wise it cuts through the tires bead = bad!!
11-05-2008, 10:08 PM | #5 |
Rock Stacker Join Date: Feb 2008 Location: Milwaukee
Looks good! Nice to see pix that show the process.
11-11-2008, 08:38 AM | #6 |
I just got a set of the blue compound Mini Rock Claws and they are not working with my beadlocks. I have yet to figure out why, but the bead of the Rock Claws pulls right out. The Rock Bashers hold just fine. Tires are the same compound and the beads don't look much differen't. I must be missing something obvious....
11-13-2008, 05:11 PM | #7 |
Pebble Pounder Join Date: Nov 2008 Location: South "O"
so all i have to do is buy 2.0 inch pvc pipe and cut it the same width of the wheel
11-13-2008, 06:37 PM | #8 |
Newbie Join Date: Jan 2006 Location: Coure d Alene
i did the same on mine but i had some stainless 2 inch pipe by 1/4 inch wall that i used just used the saw at work and they worked great wont rust when water gets in them and added alot of weight to them too
11-14-2008, 05:57 AM | #9 | |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
Now thats a good idea Make them into locks and add the needed weight @ the same time You could even use thicker wall pipe in the front and thinner in the rear to adjust the weight where you want it..I am going to give this a try Now to order some more wheels | |
11-14-2008, 08:48 PM | #10 |
so the inside diameter of the pipe needs to be 2'' or the outside diameter needs to be 2''???? help???
11-14-2008, 09:39 PM | #11 |
Rock Stacker Join Date: Oct 2008 Location: SD
Inside needs to be 2". Steve |
11-14-2008, 10:25 PM | #12 |
Rock Stacker Join Date: Sep 2008 Location: Memphis
Thanks I was wondering about this
11-15-2008, 08:40 AM | #13 |
Rock Stacker Join Date: Oct 2008 Location: US Army / Iraq
That's some impressive work for a guy who claims he can't cut a straight line with a hacksaw! The ring may need to be wider for the blue claws. The bead may be softer/thinner. On a somewhat related note, I wrap 3 rows of plumbers lead solder around the center of my wheel for weight. Works AWESOME. |
11-15-2008, 12:43 PM | #14 |
Rock Crawler Join Date: Aug 2006 Location: nc
would it be posable to get a clean cut with a mitter saw? i got my blue claws from tcs today and i still have a foot or so left of 2" pvc laying around from when i had a drift car.
11-15-2008, 09:28 PM | #15 | |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Not for me, my cuts look like crap, I ended up just using masking tape as a guide when I cut mine. | |
11-16-2008, 08:51 AM | #16 | ||
I'll post some pics later. Last edited by toybuilder; 11-16-2008 at 11:26 AM. | ||
11-16-2008, 11:20 AM | #17 |
Cutting the ring 20mm wide (.788 inches). Notice the hose clamp being used as a guide for a straight cut.
11-16-2008, 11:24 AM | #18 |
Beveled edge. I used a deburring tool. It doesn't have to be exact, just make some space for the bead of the tire to squish into.
11-16-2008, 08:40 PM | #19 |
Oh...good idea Toy!
11-17-2008, 01:41 PM | #20 |
20mm on the nose.....that's one accurate hose clamp you got there!
