11-06-2008, 12:26 AM | #1 |
Newbie Join Date: Nov 2008 Location: Dodge City
| better steering!!??
what are you guys doing to improve steering stregth and angle?
11-06-2008, 06:35 AM | #2 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
11-06-2008, 08:29 AM | #3 |
| is there a kit?
did you build it from parts or a kit or what. cost? pics?
11-06-2008, 09:52 AM | #4 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I drilled an AX10 servo mount plate and slapped a hobbico CS170 on there with a CC BEC. 333 in/oz will get it done but the servo is overvolted to 7v as well so it's probably closer to 400oz/in |
11-06-2008, 12:33 PM | #5 |
| Looks like the front does. http://www.horizonhobby.com/Products...rodID=LOSB1409 http://www.horizonhobby.com/Products...rodID=LOSB1410 http://www.horizonhobby.com/Products...rodID=LOSB1421 <--I actually just modded some other servo mount uprights I already had. Those parts, plus a 2nd servo, servo saver or arm, and either a 3ch radio or a reversing "Y" harness to reverse the rear servo. |
11-06-2008, 09:01 PM | #6 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
I run a small hitec servo. Forget the model # but I can post if you want. Its a stock replacement to a degree but way better
11-06-2008, 09:18 PM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Folsom
| more info on setups
Following the orig thread... I used an axial servo plate and drilled one hole in front center and then the right stock hole that is in the axial servo plate I was able to just tap into the orig plastic one and make my 2 mounting points.. KEY WORD Im trying to use an Hitec 645... I installed it with no issues.. BUT my issue is that when I turn left to right or right to left... MY steering will not come back to center.. now this is with my rig in the air for testing purposes.... I am using stock arms and stock horns and or servo saver... Someone who reads this has to have an idea on what I can do to fix my issue.. Thanks J |
11-06-2008, 09:26 PM | #8 |
Rock Stacker Join Date: Oct 2008 Location: US Army / Iraq
Buy a second MRC and pull everything off the front and mount it on the back. Then you have plenty of spare parts for anything else. Oh, and a servo reverser. A longer servo horn will increase the throw ratio to the wheels. |
11-07-2008, 12:37 AM | #9 |
11-07-2008, 01:37 AM | #10 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Cant really increase angle? the stock servo will move the wheels lock to lock, not sure waht's holding back the steering from going anymore-havent had enough time to look and tweak it,but with the servo disconnected the wheels still have the same radius
11-07-2008, 06:01 AM | #11 |
11-07-2008, 07:01 AM | #12 |
| Grinding on the front of the inner knuckles will help. Keep in mind though that the shafts may not like the extra angle. I haven't tested them to see what they'll put up with but you may end up having to grind the cups as well.
11-07-2008, 07:04 AM | #13 |
| was hoping for an easy fix.
for four wheel steering, where are you getting another front axle?
11-07-2008, 07:37 AM | #14 | ||
11-07-2008, 07:39 AM | #15 |
Rock Stacker Join Date: Jul 2008 Location: river ridge
no new axle the front and rear axle are the same. just buy the parts and put them on. Hint, Take the rubber o-ring out of the rear I have 4ws and IMO it is pointless if you can't control it independently. ie 3rd channel |
11-07-2008, 06:07 PM | #16 |
11-07-2008, 06:25 PM | #17 |
I used the Hitec 5245mg. It bolts in
11-07-2008, 06:27 PM | #18 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
i have the stock setup, but on my DX3R and i was able to just increase the endpoints and it did get more steering before binding
11-07-2008, 08:24 PM | #19 |
| sorry about that
when I saw the attachment I assumed it was pictures and not a parts link.
