View Poll Results: How is your transmission oriented? | |||
Stock tranny | 42 | 37.84% | |
Flipped tranny | 69 | 62.16% | |
Voters: 111. You may not vote on this poll |
11-06-2008, 06:58 AM | #1 |
| Tranny stock or Tranny Flipped?
Just wanting a head count of who runs the tranny flipped or stock. I ask because of the motor. A flipped tranny will eat up the stock motor because of the timing. I sell the TorqueMaster Mini with forward timing for a normal tranny, but if enough people run it flipped I will start sending them out with zero timing. |
11-06-2008, 07:05 AM | #2 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
Run mine flipped. Just how "bad" is it for your motor? I just switched the plugs on mine to reverse it.
11-06-2008, 07:06 AM | #3 |
Newbie Join Date: Sep 2008 Location: Celina
Mines flipped, hope it holds up until I can save some money for the TorqueMaster Mini. Tim |
11-06-2008, 07:13 AM | #4 |
It burns up the comm and brushes to run them with negative timing. Some motors may last a bit, some may destroy themselves in a matter of an hour.
11-06-2008, 07:16 AM | #5 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I just put my TorqueMaster Mini in with the tranny flipped ..... So I guess I need to alter the timing before I run it. Which way do I need to rotate it again? |
11-06-2008, 07:19 AM | #6 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
Flipped is the way to go IMO. Can't get a battery on the front links otherwise.
11-06-2008, 07:23 AM | #7 |
| Well mine's made it an little over month so far, but now you've jinxed me. lol For you to sell them for a reversed tranny is it just a matter of you adjusting them? I was planning on getting one anyway, but maybe I'll get it sooner than I'd planned on |
11-06-2008, 07:32 AM | #8 | |
Loosen the little endbell screws and line them up with the dents in the can. The endbell will rotate clockwise in relation to the can. | |
11-06-2008, 07:43 AM | #9 |
Good info! Mine is flipped.
11-06-2008, 08:43 AM | #10 |
Rock Stacker Join Date: Jun 2007 Location: MILAN
Mine is flipped, made room for the battery, and also seemed to help the torqe twist (could just be in my mind though) |
11-06-2008, 08:53 AM | #11 |
Rock Stacker Join Date: Oct 2008 Location: US Army / Iraq
Mine is flipped. Oddly enough my motorcycle motor (280 size) runs with the positive and negative leads connected properly. Perhaps some kind of reverse - wind thing because it's designed for RC bikes? (Yes, my throttle switch is forward on my radio.) |
11-06-2008, 08:58 AM | #12 |
Mine was flipped and turn it back to stock.
11-06-2008, 09:05 AM | #13 |
Newbie Join Date: Nov 2008 Location: Dodge City
| is there any other advantage?
besides battery relocation room, is there any other advantage?
11-06-2008, 09:14 AM | #14 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| looks like you need to offer them both ways ! non-flipped tyranny. got one of these motors form JRH & its a "BEAST" these little motor rocks ,a lot faster & more low end |
11-06-2008, 09:17 AM | #15 |
I still run mine normal
11-06-2008, 10:01 AM | #16 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Did not even try it out normal, flipped to make room from the get go
11-06-2008, 10:02 AM | #17 |
I don't see any other advantages to the flip. I think the battery space alone is enough for me though.
11-06-2008, 11:00 AM | #18 |
Quarry Creeper Join Date: Apr 2008 Location: dallas
I am running the Torque master mini with the tranny in the stock position.. |
11-06-2008, 11:12 AM | #19 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
im running my tranny stock but i have it hoocked up to a gear ruduction heres a pic, am i gonna need to adj the timeing? |
11-06-2008, 11:40 AM | #20 |
Rock Stacker Join Date: Oct 2008 Location: gainsville
| flipped
I flipped mine. And burned up a torgue master up in 30 minutes. Had to have john fix it.
