11-11-2008, 01:20 PM | #1 |
RCC Addict Join Date: Oct 2008 Location: 209
| drivelines
hoe makes hd. drivelines. twisted one
11-11-2008, 01:25 PM | #2 |
Quarry Creeper Join Date: Apr 2008 Location: dallas
huh?
11-11-2008, 01:40 PM | #3 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
11-11-2008, 01:49 PM | #4 |
yes thats what i was trying to say. any ideas what to make them out of.
11-11-2008, 01:58 PM | #5 |
Rock Stacker Join Date: Sep 2004
Ho twisted my driveline once.... yes, i'm bored. Seriously though, I haven't seen any aftermarket (if that's what you're after) How did you bust yours? inner/outer? Crawlski was talking about lengthening drivelines in his thread about his Cherokee scaler. "l-trail Grand Cherokee" Maybe pm him for a source? EDIT : nevermind, I checked again and it looks like he's running stock wheelbase. sorry. |
11-11-2008, 04:30 PM | #6 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
I got stamped drive shafts to work and have'nt twisted one yeat. losi 1.9 mini slingshot mongoose |
11-11-2008, 09:57 PM | #7 |
Newbie Join Date: Sep 2006 Location: Pocatello
Been running mine for awhile and have not seen an issue. Let me know how the upgraded ones work
11-11-2008, 10:05 PM | #8 | |
I wanna be Dave Join Date: Oct 2006 Location: Centered
11-11-2008, 10:19 PM | #9 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I slapped in some pede shafts. Here is how I did it: http://www.noeither.com/rc/tech/mrcdriveshaft.php |
11-11-2008, 11:09 PM | #10 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
| mrc hd driveline
Hi, I don't have alot of time right now , but, drill out the u joint on a 1/10 scale Any will do but I used traxxas revo. I used a 5/16 and then cut the u joint from the losi so all you have is a bushing, Slide the bushing inside the larger u joint and get a longer set screw and go thru both u joint holes and there you have a HD driveline that looks like original equipment because there are no cuts to be seen except for where you have to cut the 1/10 drive line shorter. I will post up pics if there is an interest. Got to go for now. EDIT : the rear output has to be ground down a bit, and the motor plate dremeled . The larger dia. shaft rubs against the trans plate and housing. Last edited by motorman1600; 11-13-2008 at 11:40 PM. |
11-11-2008, 11:36 PM | #11 |
Hot-Racing and 3Racing have them in the works if you can wait. Hot-Racing http://www.hot-racing.com/?partnumber=MRC37H08&c=444 3Racing http://www.3racing.hk/products.php?products_key=3669 |
