11-14-2008, 05:50 PM | #1 |
Newbie Join Date: Feb 2007 Location: so cal
| bending options
i wanted to bend my stock links but would it be bad to bend both front and rear? should i just bend front? or should i bend the rear links? i am very new to this and just want to see if anyone has done this allready and have feedback?
11-14-2008, 06:19 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
If you bend the stock links its gonna shorten them. so unless you do something with the upper part also its gonna mess with your pinion angle. As far as bent links go - id run them front and rear, but I think id just make new lowers that are bent.
11-14-2008, 06:33 PM | #3 |
do i go to the local hobby shop to get the tubing? ive never fabed links does seem like to much to do...
11-14-2008, 06:36 PM | #4 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
Personally I would advise against bent links on the LMC. The pinion it quite low and I think you would run into trouble with the drive shafts catching on rocks. But if you do want to try it out make new links don't bend the original ones.
11-15-2008, 12:15 AM | #5 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
all 4 of my lowers are bent, and i have no such problems, i adjusted my rear pinion angle with my custom tri-link. |
11-15-2008, 05:04 AM | #6 |
11-15-2008, 09:44 AM | #7 | |
Rock Stacker Join Date: Jul 2008 Location: river ridge
unless you clock the diff I have rear steer on my mrc and a clocked rear diff and the king pin angle is 17ish deg. steering link sits level to the axle and steering is still very good. | |
11-15-2008, 01:26 PM | #8 |
| macruz said it all, lol |
