Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Body clips
Old 11-14-2008, 11:29 PM   #1
Default Body clips
Ok i am getting really tired of my body clips falling out on this thing. What are your guys' answers?
h8z2luze is offline   Reply With Quote
Old 11-15-2008, 12:13 AM   #2
try puting 2 holes in the hood (bout 1/4-1/2 in apart) and put a ruber band trew 1 hole and bring it out the other then hook a body clip to each end that way u wont lose them when they fall off cuz if u make them stay in they will be harder to get out
bar321 is offline   Reply With Quote
Old 11-15-2008, 12:15 AM   #3
I have those elastic bands that were made for that but they look stupid. Especially on the mrc. Thanks for the idea though!
Old 11-15-2008, 01:23 AM   #4
If you tie each body clip together with some fishing line it won't be as noticeable as the rubber clip retainers. I run the big ugly rubber cause I'm a lazy bastard...
GixxerGeoff is offline   Reply With Quote
Old 11-15-2008, 01:28 AM   #5
i use the dubro clip retainers, no better alternative yet.
JOOTZ is offline   Reply With Quote
Old 11-15-2008, 01:54 AM   #6
I just put the loop end of them forward, and have my posts trimmed + the clips in as far as I can squeeze the body. When I lose one or two, I just hack up a paper clip to make more. Since trimming them and clipping as far in as I can I haven't lost one.
Trike Kid is offline   Reply With Quote
Old 11-15-2008, 02:30 AM   #7
Who's your Daddy-0!
Fishing line works great, just connect 2 of them together. You cant see the line so it's not that bad Or just drive better and you won't loose them
TattooKenny is offline   Reply With Quote
Old 11-15-2008, 02:36 AM   #8
MWRCA'er
Mnster's Avatar
Fishing line is great, used that many times.
Also using zipties to lock the clip works great as well.
Mnster is offline   Reply With Quote
Old 11-15-2008, 02:59 AM   #9
Ya I lose one everytime I crawl it seems like. Thanks guys!
Old 11-15-2008, 09:25 AM   #10
I use a different approach . I cut 4 pieces of regular fuel line , about a 1/4 of an inch long , and slid them onto the posts all the way to act as a stopper inside the body . Then I used extra heavy ( thick ) fuel line , used for planes / boats I think , and cut 4 pieces about 1/2 " long , and these are slipped over the mount and snugged up to the body . This set up acts as a rubber mount for the body as well , and the issues with bodies breaking has gone away for me . Looks ok , I color matched the tubing to the truck body color hahaa . And the local course no longer eats 6 or more body mount clips per comp lmao .
outlikealight is offline   Reply With Quote
Old 11-15-2008, 11:27 AM   #11
sounds good, any pics ?
Old 11-15-2008, 11:31 AM   #12
Yeah that is a good idea.
03ssilverado is offline   Reply With Quote
Old 11-15-2008, 12:53 PM   #13
No , no pics sorry , cam isnt working at the moment . I went to the LHS and looked at odd ball fuel lines . It is real thick walled the stuff I got . Double to tripple nitro fuel lines thickness . Works great , had a lot of comments on it so far , and a bunch of clones in my area now too hahaaa . Even if you just use regualar nitro line on the inner , and a reg body clip outter , they seemed to not fall out as much . Maybe the rubber mount taking away shock , and that extra slop ? I dunno , but I sure like mine : )
Old 11-15-2008, 06:49 PM   #14
I had good luck on both my losi and ax10 using AE buggy wing clips(the long blue ones)
They work great, and would have to fall out of both posts to get lost
TooSlow is offline   Reply With Quote
Old 11-28-2009, 08:24 PM   #15
I dont use the clips, body sometimes comes loose if it tip over, which isnt much. I also ran my shocks in the same hole as the body mount which moved the mounts out further so it holds the body better. I would tie a small string between the 2 pins that way if 1 falls out the other will hold it.
mikegigabyte is offline   Reply With Quote
Old 11-28-2009, 09:15 PM   #16
http://www.lunsfordracing.com/mm5/me...Code=ROCKSCREW
but you will have to fab body posts
rex cars is offline   Reply With Quote
Old 11-29-2009, 01:18 AM   #17
Move the posts. One post in the back and one in the front of the chassis sticking up. It lets the body rock side to side which helps when you flop over because it lets the chassis rock sideways so your tires will hit the ground and move the truck. Haven't lost a body pin since in moved the posts.
stubs179 is offline   Reply With Quote
Old 11-29-2009, 11:54 PM   #18
Build a ROCKSHOW mrc by T1E and never use a body clip again!!! HA HA!
picklewagon is offline   Reply With Quote
Old 11-30-2009, 02:59 PM   #19
i just spun mine so that the holes in the post are vertical instead of horisontal and i havnt lost one yet
crawler pilot is offline   Reply With Quote
