11-16-2008, 04:29 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Bismarck
| What to use to mount the elctronics to 3 link arm?
What do you guys use to mount you eletronics on you 3link arm on the losi mini crawler?
11-16-2008, 04:32 PM | #2 |
RCC Addict Join Date: Nov 2008 Location: never been
i cut a piece of lexan and CA`ed it to the arms, servo taped the stuff i wanted to it.
11-16-2008, 08:25 PM | #3 |
I have a couple of uncut, unpainted lexan RC bodies laying around. There was enough excess material around these bodies for me to cut out triangles that fit on the upper links. The good thing is that the upper links have a groove on them that hold the plastic in place when you set it on the upper link. Then I drilled holes in the lexan and used zip-ties to hold the links on. I thought about using CA, but decided to go with zip ties since they, to me, are easier to remove.
11-16-2008, 08:34 PM | #4 | |
Newbie Join Date: Sep 2008 Location: Chambersburg
Did the same thing, as did most people, and it seems to work just fine. | |
11-16-2008, 08:47 PM | #5 |
Newbie Join Date: Nov 2008 Location: Canada
I used a lid from a sandwich container. A clear blue one, very stiff material and looks cool since I have the blue one. I crazy glued it to the arms.
11-16-2008, 09:26 PM | #6 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
11-16-2008, 10:58 PM | #7 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
.040" Styrene zip tied to the links here. Had things taped for a while but I switched to zip ties for the battery and ESC because I didn't have actual servo tape, but I have a pack of about 1200 zip ties, and they hold up to my driving better.
