11-18-2008, 01:56 AM | #1 |
Newbie Join Date: Jul 2008 Location: around
| Question on a setup
I have and love my MRC. I really would like to build a scale looking Tough Truck. I need a good bit of wheel speed and torque. Can someone give me some some ideas on a motor, battery, maybe pinion spur gear setup. I would like to get the holmes hobbies torquemaster mini, but im not sure what will be enough. Any info would be much aprecated. THX
11-18-2008, 09:03 PM | #2 |
Somebody on this site recommended the Reedy Stump Puller motor and said that it was faster than the Holmes motor. If this you ever follow through this will be a cool build to see!
11-19-2008, 12:56 AM | #3 |
Thx...will I be able to use the stock ESC with any of these motors?
11-19-2008, 04:03 AM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
I just installed a Venom fireball mini 370 in my MRC and it was twice as fast as stock with the stock battery. I then went to a Thunder power 1320 2S lipo and it works great. Cost me about 16 dollars for the motor from the local Hobbytown and I had the Thundrpower pack from my flying days. You just have to swap out the motor wire connector and grind a flat in the motor shaft for the pinion set screw. |
11-19-2008, 12:49 PM | #5 |
Thx guys for the info I will call up my local hobby shop get me one.
11-22-2008, 05:51 PM | #6 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I have the Holmes Hobbies torque master mini with a 1650mah lipo and it seems to be geeking out my stock esc...hesitation and stalling. Going to get a tekking fxr |
11-22-2008, 06:17 PM | #7 |
RC Axle Master Join Date: Mar 2008 Location: Las Vegas
I installed the Holmes Hobbies 454 Cobalt Puller with the CC Mini Mamba ESC using a 2700mah 2s lipo. It works great but you will need to modify the motor plate to fit the puller. Also you will need to loosen the side chassis screws from the skid to get the motor to fit in. I've been running this for a few weeks now with no problems.
11-22-2008, 07:11 PM | #8 |
Pebble Pounder Join Date: Sep 2008 Location: B.C., Canada
| a better method would be to cut the tvp next to the motor. instead of loosening the skid plate=sloppy truck
11-22-2008, 07:51 PM | #9 |
Newbie Join Date: Oct 2008 Location: Bend
I would try a fireball 370 with a 15 tooth pinion. I run a fireball motor with an 11 tooth pinion and its faster than stock so I imagine with a 15t it would move pretty good Ben |
11-23-2008, 11:12 AM | #10 | |
The screws only need to be loosen to make it easier to get the motor and trans in. Then retighten the screws nothing is loose and the chassis remains the same, works great. The hard part is modifing the motor plate without screwing it up. | |
