11-21-2008, 12:00 AM | #1 |
| Griz's Team RCC/Holmes Hobbies Reign R/C Losi Mini
So I finally picked one up a couple weeks ago. I'd driven rubbaneck's before but after watching the 1.9 class run at the last comp, l just had to have one. First here are the specs: Mamba25 ESC Castle BEC Hitec 645MG Losi Mini-T springs/stock black rear spring Stock wheels with bb's for weight Ace's 1.9 memory foams mini Masher 2000's Losi Bronko body E-flite 800mAh LiPo Since I can't stay away from the Bronco bodies I thought I'd name this one The miniDuke as a tribute. I'm really happy with how the Team RCC colors turned out. Hope you like it. |
11-21-2008, 12:07 AM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Oroville, CA
Very awesome!
11-21-2008, 12:07 AM | #3 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
lookin sweet griz those cutdown m2ks look like they might be the hot ticket |
11-21-2008, 12:08 AM | #4 |
Nice work Chris. The colors are just in time for Christmas |
11-21-2008, 12:09 AM | #5 |
Before I bought it I knew what changes I wanted to make to improve it. First thing I did was move the rear upper link. I drillled and tapped the end to 3mm and installed a shock rod end from my parts box. Then I mounted a TLT link mount to the rear servo plate. This put the rear link at a better angle and reduced torque twist. It caused more axle swing under articulation but it's livable. Next I limited the shocks. I opened them up and replaced the internal plastic limiter with some fuel tubing. The pieces I made are twice the length of the plastic ones. I then filled the shocks with some Traxxas oil I had. It seems to be about 30wt. With the shocks being shorter I used Mini-T rear springs. I left the stock black spring at the left rear and put a blue mini-T spring on the right rear. The front shocks got green mini-T springs. These mods have reduced the articulation and ride height and the torque twist seems to really be under control. The 645 servo was mounted with an Axial servo plate and TLT servo mounts. The steering link was made from a short Traxxas link. To help the 2mm screw fit in the rod end a little better, I used one of the brass sleeves that comes with the servos. It's still a little big but it seems to work for now. |
11-21-2008, 12:13 AM | #6 | ||
| Thanks man. Quote:
Darn you, I thought the colors just looked cool. Now I'm just thinking of Christmas when I look at the pics. | ||
11-21-2008, 12:30 AM | #7 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
I like it. (The color and BronKo body) But it needs some different tires, never been too impressed with mashers. I know they have a big following but they just never seemed any better than what I had been running. Maybe it's just me. Is that Kirby Morgan dive gear your sporting in the pic on your desk? Last edited by racerx; 11-21-2008 at 01:42 AM. |
11-21-2008, 12:56 AM | #8 |
Rock Stacker Join Date: Mar 2008 Location: Its a language (not mine) and a utensil all rolled into one messed up city.
I like it, ... I really like it. |
11-21-2008, 12:58 AM | #9 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
decent |
11-21-2008, 01:04 AM | #10 |
Very nice sir. I need to get a bigger servo on mine. Have you added any weight yet?
11-21-2008, 05:03 AM | #11 |
It's a Mini Me... |
11-21-2008, 07:33 AM | #12 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Very nice!!
11-21-2008, 08:30 AM | #13 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Great, another one... Looks fine and dandy Chris, I like the upper link mount addition too. Keep the wrenches turning. |
11-21-2008, 09:02 AM | #14 |
Looking good Chris the Bronco body is very good fit for sure.
11-21-2008, 10:13 AM | #15 | |||
I went with the Mashers because I had them laying around and I have to limit my R/C spending right now. Hopefully they will work ok for now. Good eye Robb. Yup, that's me putting on a Superlite 17 on a jack-up barge in the Gulf of Mexico. Back when I was commercial diving. Thanks JSS. We'll start here and see what needs to be tweaked. It seems to be quite a bit better than stock though. Quote:
I did add weight, the wheels are full of bb's under the foam. I thought I'd start with that and the servo adds some extra weight to the front end. If needed I can still add lead to the inside of the wheels. I didn't want to go overboard on the weight right away though. Yes it is! Thanks Jarod. Thanks Franky, it's a start anyway. Quote:
Thanks Norm. I knew from the moment I saw an MRC that I wanted to put the Bronco body on it. It turns out to be the perfect size. | |||
11-21-2008, 10:18 AM | #16 |
RCC Addict Join Date: Aug 2005 Location: Pocatello
Once again another super cool build from Griz. Gonna post some pics up with miniduke on the rocks?
11-21-2008, 11:02 AM | #17 |
varcor.org Join Date: Aug 2005 Location: 757
| i like what you did with the upper link chris. i planned on doing a 4 link in the rear of mine but i may just have to try this first. my shocks are setup the similar to yours minus the mini-t springs, i think my LHS has a set of sitting on the shelf i may have to get now. and love the body in the Team colors!!! |
11-21-2008, 11:11 AM | #18 | ||
My first thought was to do a 4-link also. But then this idea came to mind so I thought I'd give it a try. This weekend will reveal alot about the setup. | ||
11-21-2008, 11:21 AM | #19 | |
Rock Crawler Join Date: Mar 2008 Location: Arizona
If you cut the stock link in half and drill/tap it for the rod you get 2 rod ends with the right size balls. | |
11-21-2008, 11:25 AM | #20 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
wow great ideas on the rear top link. the body is awesome . i love those little bronco s . little mashers are cool too. keep it up! |
