11-22-2008, 07:03 PM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Fresno
| Is it possible?
To squeeze a 645 into the stock servo mount?
11-22-2008, 07:08 PM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: B.C., Canada
prolly not but it isnt hard at all to make a new servo plate to mount the servo on the axle
11-22-2008, 07:11 PM | #3 |
If i have to make a mount then i'm getting a 225.
11-22-2008, 08:58 PM | #4 |
Newbie Join Date: Oct 2008 Location: Bend
11-22-2008, 09:28 PM | #5 |
My cousin has a 645 i can use, so i'm going to make a aluminum servo mount tomorrow.
11-23-2008, 08:06 PM | #6 |
Pebble Pounder Join Date: Sep 2008 Location: Thornton
Mule on here has one on the stock plate... Just has it bent and 2 bolts diagnol from each other holding it in. It isn't hard to make one though.
11-24-2008, 08:37 AM | #7 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I have a ht645 on my mini. It will not fit on the stock servo mount cleanly. I fabed one up from lexan and it worked fine. |
11-24-2008, 08:43 AM | #8 |
Quarry Creeper Join Date: May 2008 Location: Franklin
If you also have an Axial AX10 servo mount just use one of those and superimpose the bolt pattern onto it. Works like a charm.
11-24-2008, 10:19 AM | #9 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
11-24-2008, 12:45 PM | #10 |
Pebble Pounder Join Date: Mar 2008 Location: Rock Springs
the 225 is working fine for me ]
11-24-2008, 01:11 PM | #11 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
11-25-2008, 07:47 PM | #12 |
Do standard aluminum hitec servo horns fit a 225?
11-25-2008, 08:29 PM | #13 |
11-25-2008, 08:32 PM | #14 |
Alright i'm just going to go with a 225. You guys can whine and gripe, but i'm going with it. If it goes out, it goes out. My stock servo has held up fine all week without a servo saver. Worst comes to worst, i know someone with an extra 645.
11-28-2008, 11:55 AM | #15 | |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
Good luck!! | |
11-28-2008, 12:17 PM | #16 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
you can use a novak or castle creations BEC to help power the bigger servo and save the ESC
