11-25-2008, 12:13 PM | #1 |
Pebble Pounder Join Date: Mar 2008 Location: Rock Springs
| problem with wheel extenders
Hey all, I did a search and couldn't find what the answer I was looking for so... I ordered some G-made wheel extenders for my LMC and the screw post/nut is to big to fit in the RC4WD python rims I have and the mayhem rims also it is too big. Is it hard to drill alum. rims (I don't have a drill press or a vice) by hand? I really don't want to ruin my new rims I may have to bite the bullet and buy a 10" drill press and vice. thanks in advance |
11-25-2008, 12:18 PM | #2 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
If you have some way of clamping the wheel down so it doesn't move and are sure to keep the drill straight, you shouldn't have any issues drilling them, aluminum isn't that hard. Keeping the wheel somehow clamped down and flat is going to be the biggest thing, if you don't, you can end up hitting the face of the wheel with the drill bit, bent drill bits, crooked holes etc... Bits like to "catch" when enlarging a hole.
11-25-2008, 12:18 PM | #3 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
I had to drill my stockers out for the extenders too. I used a drill press on mine. I would say that if you use a hand held drill and you're nervous about drilling them to start small on the bits and work your way up to the correct diameter. Aluminum is normally not too bad to drill (it's a fairly soft metal).
11-25-2008, 12:41 PM | #4 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
it can easily be drilled with a hand drill. i have a press but always drill those by hand. just drill slow so it doesnt get away from ya
11-25-2008, 01:10 PM | #5 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
My advice is this, drill out your stockers to see if you even like the wheel wideners. I have sweet aluminum wheels and when I got the wideners I was so excited that I just want to drill my wheels to make them fit. I ended up taking it slow and just drilled my stockers to test the wideners. Guess what...in my opinion the wideners kinda sucked, like really, they make the rig sloppy, it will get hung up on everything and the steering radius become like a 2.2. In fact it basically feels like driving a 2.2 rig with tiny tires and no power for steering. Drill the stocker and try out the wideners before you drill some nice aluminum wheels. The most challenging part about this process is dealing with the fact that you spent money on parts that could be useless depending on if you like them or not. DO NOT DRILL YOU NICE WHEELS... until you test the wideners on the stockers and you know for sure. Good Luck bro |
11-26-2008, 10:52 AM | #6 | |
RCC Addict Join Date: Nov 2008 Location: never been
thats good advice on there, i have been waiting for my 1.9 eritex heavies(2 weeks now, sic ) and will have to test on stock width before i take the drill to it. | |
11-26-2008, 11:50 AM | #7 |
yeah I think I will drill out my stock rims and give them a try with the extenders. thanks |
11-26-2008, 12:16 PM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: right above my feet
i drilled out my mayhems for the extenders. Going back to no extenders is fine, the hex centers the wheel on the axle, so the slightly larger hole doesn't make much difference.
11-26-2008, 12:37 PM | #9 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
I hate hand drills for this type of stuff. A small drill press at lowes is like $100.00-$130.00 and you will have it forever. And they work great for this kind of work. I like the idea of using the stk. wheels to see if you are going to like them or not.
11-26-2008, 04:56 PM | #10 |
one thing i noticed though is that with my CAC BAMF-1 2inch and the eritex 1.9 heavies which just came in today i didnt have to drill into them, the long bolt for the widener fit like a glove. test fit yours before anything.
11-26-2008, 09:39 PM | #11 |
yeah, the hole was too small I drille out the plastic stock rims no problem. I will run it this friday at my LHS and maybe (if the wether is above freezing) outside this weekend.
11-26-2008, 10:40 PM | #12 | |
good luck on that, if you do need to drill your nice rims you could maybe bring it to a machine shop and have them do it for you. | |
