11-28-2008, 01:30 PM | #1 |
Newbie Join Date: Nov 2008 Location: Akron
| Losi Mrc Servo
Hello, this is my second post on here. I bought a Hitech HS-225MG servo but the teeth do not match the steering rod teeth. Any help or a different servo suggestions will be much appreciated. Thanks, PiLot |
11-28-2008, 01:42 PM | #2 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
I'm running one but just using a Hitec specific servo horn. Mine is a Dynamite DYN2561
11-28-2008, 06:28 PM | #3 |
Newbie Join Date: Jul 2006 Location: Highland Village
When I was running the 225mg, I ran the red servo horn that came with it, cut down.(cut 3 af the arms off) and ran the stock ballstud on the front, with a nut on the back. Make sure you turn the throw down on the radio, or else youll overheat and kill the servo! Good Luck! -Scott |
11-29-2008, 07:00 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
11-29-2008, 07:39 PM | #5 |
Yup, same plastic Losi links it comes with. I did grind a little off the servo arm for my setup. Mine is on a hand made servo plate though, so I'm not sure if you would have to grind any off if you use the stock one.
11-29-2008, 08:07 PM | #6 |
Thanks, after reading your post redmike, I rounded up my box-o-parts and checked the clearence of the servo arm. I will prolly have to grind a little away to get it to fit. Should be no problem.
11-30-2008, 09:27 PM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Fresno
I didn't grind mine. It may rub a fraction of a hair, but nothing that will affect the servo.
