12-02-2008, 10:08 PM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
| What weight oil on droop?
What weight oil do I want to use with a droop set up, with MLST size shocks? Its got 1.5oz weight in each front wheel and 1oz in each rear. Im going with the droop with the hope of lowing the COG a little bit, and getting rid of the torque twist.
12-02-2008, 11:14 PM | #2 |
Pebble Pounder Join Date: Oct 2008 Location: albuquerque
Before u get flamed best search the topic is every where. I ran droop for about a week wasn't for me but it didn't make the torque twist any different.
12-02-2008, 11:50 PM | #3 |
Holdin my 40oz. Join Date: May 2008 Location: Somewhere in Colorado
I'm running droop with stock mini-lst shocks w/3 hole pistons with 40wt oil and no springs at all. two of the piston holes in the front are drilled out to 1/32nd or so and one of the piston holes in the rears are drilled out the same. Basically making the holes twice as big. anyway, it works awsome. My links are now flat at ride height , and I really like it, it's very predictable, so if youre lookin for a starting point that should do.
12-03-2008, 12:30 AM | #4 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
I think it kind of depends how you want the suspension to react? I ran the stock shocks for a little while in a droop setup and was using 60wt. oil running the same weight you are and liked it. I say start with 40wt. and see how you like it. You can always change it |
12-03-2008, 07:44 AM | #5 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I am running 75wt in the stock shocks right now. I might go thicker to 90. I like the way droop works with these rigs.
12-03-2008, 01:13 PM | #6 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
test and tune are you running an internal spring? oil wt would depends on the spring.... |
12-03-2008, 10:49 PM | #7 |
Rock Stacker Join Date: Nov 2008 Location: nor cal
newbie f/up....put 1.000 diff oil in my new hot racing shocks...actually works good...but the right oil i am sure is better>>>newd out!!! |
12-03-2008, 11:20 PM | #8 | |
RCC Addict Join Date: May 2005 Location: Auburn, WA
I run droop on the rear of my truck only (stock shocks in the front set for compression only, works best for me and no torque twist going forward at least) and I'm running just fine with 25wt oil and some internal springs in Evader BX rear shocks, without the springs, it wouldn't be half the damping I'd need. | |
12-04-2008, 01:02 PM | #9 |
So I really like the way it drives with 45wt oil in it, but its still will torque twist climbing up steep inclines, what do I need to do to make it stop that? Will 4-linking it work? Are there any down sides to making a 4 link set up?
12-04-2008, 01:12 PM | #10 |
A four link will help. Don't think there are any downsides to a four link setup either. Maybe add a little more weight to the front wheels/tires? Maybe some Blue Compound tires? Maybe don't climb such steep inclines |
12-04-2008, 01:16 PM | #11 |
| On the blue compounds. I wanna climb steep stuff though! |
12-04-2008, 03:58 PM | #12 |
Ballpoint pen springs with 1/4" fuel tubing limiters. Seems just right. |
12-04-2008, 06:14 PM | #13 |
Would the limiters be on the inside or the outside of the shock?
12-04-2008, 08:05 PM | #14 | |
Think about it. If you put the fuel tube on the shock shaft outside of the shock body it's going to limit up travel. If you put the fuel tube on the shock shaft inside of the shock body it's going to limit down travel. | |
12-04-2008, 08:45 PM | #15 |
So I would put it on the outside to limit torque twist then? And the little springs on the inside.
12-04-2008, 08:52 PM | #16 | ||
Try it you will see. It works pretty well. RCP should have my mini blackjack out soon as well. | ||
