12-06-2008, 12:57 AM | #1 |
Newbie Join Date: Oct 2008 Location: elgin
| 4 link build?
who have done a 4 link on the mrc.. and parts have u used and how do i go about building it right do links need to cross lowers to work right for help lower tq tewst???? and what part # for like link ends im new to building this stuff so not so sure where i can look to find end links and ball links that fix to each other and to the frame to... thanks for the help..
12-06-2008, 02:25 AM | #2 |
Newbie Join Date: Nov 2008 Location: ds
I used some traxxas ends I found at the local hobby shop and some threaded rod. |
12-06-2008, 08:32 AM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: albuquerque
I read a thread about mods for mrc's and there was a quick write up on a 4link search for mods for mrc.
12-06-2008, 09:53 AM | #4 |
Rock Crawler Join Date: Mar 2008 Location: lodi
pretty much u will need a new 4 link plate, rod ends and some form of rod. i used some axial braces for my rods and used a peice of scrap alum for my 4 link mount. u might want to try and get some all thread to use first so u can customize your 4 link length till you feel comfortable with the set up and use some delrin rod which can be picked up quite cheep through a plastic supply store like tap plastics. theres a bit og geometry in the 4 link set up so if your new at this i woudl start out with the all thread to dial in your set up then use somethign a little more "pretty" then a peice of threaded rod for your final 4 link.
