12-07-2008, 09:43 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: willows
| Droop MRC
Heres a picture of my mrc in the hills was pretty bad went to get x-mas trees and no snow even at the top of the mountain but had fun. My drooper is running stock shocks with heavy oil and no springs, but fuel tubing outside for limiting, it runs ok but I think ill be added internal springs as soon as I get time. It has all stock electronics but everything is on the links and no more battery tray it was tossed and put in 60mm axial rods for support. I dont like the stock plastic lockers cause mine went out on my second drive. Was worth buying and is definately a change from running a 2.2 well heres a picture and I might post up a video. |
12-07-2008, 10:27 AM | #2 |
I don't know how you people are blowing your stock drivetrain pieces with the stock electronics. This is what the slipper clutch is for, but I have to say my slipper has never kicked in. They have it extremely tight from the factory. I also bought Axial 60mm links. Could you please post photos of how you have the Axial links and shocks mounted on yours? I tried running my stock MRC with a droop setup just by removing the springs. I liked it because it lowered the CG significantly, but it also took away too much ground clearance. |
12-07-2008, 11:32 AM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| He's using fuel tubing to adjust his ride heigth, but still keep a good low CG.
12-07-2008, 01:51 PM | #4 |
Ive got a few foot of fuel tubing so I could throw a couple pieces in an envelope for a couple people if needed. Ill try to post some pictures up later today.
12-07-2008, 07:46 PM | #5 |
12-07-2008, 08:40 PM | #6 |
Newbie Join Date: Feb 2006 Location: Hesperia
| Me either...i have probably damn near 2 pounds of weight added to various parts on mine and i abuse the piss out of it and havent broken anything yet other than a steering servo...
12-08-2008, 08:02 AM | #7 |
Dont know how it happened, bought it took it to the paradise comp and then the day after I noticed that my left front wasnt grabbing like it should so now im gonna order new lockers. If I can get my little video up you can see its not locking up like it should.
12-09-2008, 12:24 PM | #8 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
I have a Holmes torque master mini, and a 1650 lipo and havn't broken anything after 2 months of abuse. Of course now I will 2nite.
