12-22-2008, 05:47 PM | #1 |
Newbie Join Date: Dec 2008 Location: Santa Margarita,CA
| steering servo upgrade
Hey all... What's the best upgrade ? (not going to a huge servo) I've be doing alot of searching and can't find much info...between me and 4 others we've gone through 3 stock ones ...The ones we purchased from the local hobby store arent a direct replacement (splines a little off) and are by no means an upgrade in tork.... give it to me simple,I'm mostly into 1:1 not an RC guy Thanks ....supposedly productsupport@horizonhobby is sending me a call tag tosend back the servos for replacement...we'll see if it shows |
12-22-2008, 06:01 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Jamestown
some people are using the HS-225 by Hitec and getting good use out of them. But honestly if you are going to comps or even just playing rough with it then you will want to stpe up to an HS-645MG you wont be disapointed and you will be far less likely to burn it out. Just get your hands on an axial servo mount and re drill it to fit for the larger sized servo.
12-22-2008, 06:04 PM | #3 |
Quarry Creeper Join Date: Mar 2007 Location: Kerman, Ca
If you want to stay with the same size(mini) go with the Hitec 225mg. I don't know what the stock servos torque rating is but the 225 is 66 oz/in. I use mine with an aluminum servo horn. Works great.
12-22-2008, 06:13 PM | #4 | |
Thanks for the quick replies | |
12-22-2008, 06:16 PM | #5 |
12-22-2008, 06:49 PM | #6 |
a real quick search turned up these Mini Me's mini NiNo build! Kaetwo's Losi MRC's Griz's Team RCC/Holmes Hobbies Reign R/C Losi Mini CR/CC Comp 1.9 MRC Development |
12-22-2008, 09:25 PM | #7 |
Newbie Join Date: Aug 2007 Location: Rock Springs
I re-drilled the upgrade Losi servo/battery mount and went with the Futaba S9350 servo and a Losi aluminum Futaba servo arm. The servo has a lot of torque and works great in binds. DJ æ |
12-22-2008, 10:50 PM | #8 | |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
12-22-2008, 11:58 PM | #9 |
my buddy siezed up a 225mg tonight looks like the 645mg is the ticket...thanks for all the info
12-23-2008, 12:23 AM | #10 |
Quarry Creeper Join Date: Oct 2008 Location: Fresno
With the correct epa's the 225 shouldn't die. My stock servo still worked after a couple weeks of hard bashing.
12-23-2008, 06:27 PM | #11 |
12-23-2008, 06:48 PM | #12 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
| EPA = End Point Adjustment Are you using the stock radio? If so make sure that the knob labeled ST.D/R is adjusted so the servo does not bind at full throw of the steering wheel on the controller. Your 225 will thank you and last a lot longer. Any servo will benefit form this simple adjustment. |
12-24-2008, 01:48 PM | #13 |
just to add to my thread... my buddy who's servo went out 10 minutes out of the box,who then replaced it with the suggested 225mg....later that night the magic smoke came out of his speed controller ...he returned it to the hobby store that it was purchased at and they told him he had to run a digital servo and that was what caused his problem....They gave him a full credit for the servo they sold him,replaced the smoked parts free of charge and reassembled the car for him while he waited......the suggested servo was a 60 dollar digital servo but said they would back any failure after that. Thoughts ?? ( besides punctuation,spelling and grammar ) |
12-25-2008, 09:29 AM | #14 |
Newbie Join Date: Sep 2007 Location: channahon
stock servo on the losi is around 50, i would recomend a bigger servo
12-25-2008, 03:23 PM | #15 |
RCC Addict Join Date: Nov 2008 Location: never been
most everyone here, me included use the 645. in the long run you save money from buying another replacement, also if its good enough for a 1/10 crawler...
12-25-2008, 03:26 PM | #16 |
| I am using an extra 645 i had laying around with a spare axial servo mount i had. Works 10x better than stock and didn't cost me a penny.
12-26-2008, 09:19 AM | #17 | ||
12-26-2008, 09:43 AM | #18 | |
I almost feel bad for them...They put on some high zoot 75.00 dig. mini servo on my friends and he killed it on the carpet before he even left the store....They are definetly going out of their way for us ... I have not had any problems with my 225 yet but I'm expecting them...I should probably upgrade before it goes out but I'm starting to neglect my 1:1 buggy because of this little guy Thanks for all the input ! | |
