01-03-2009, 05:46 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Bend
| servo question.Please help!
So i think my servo went out today. All it does when i turn to the right is humm and i hear kind of a grinding sound coming from the servo. the quetion is, What kind of servo is good? Will the aftermarket servo bolt right on? will the new servo wires fit right into my electronics? My stock one sucks a$$. fill me in fellas, Jeff |
01-03-2009, 05:50 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Folsom
You can go with a Hitec 645.. you will have to purchase an axial servo plate....easy bolt on... would also rec. buying a BEC from Castle...
01-03-2009, 05:53 PM | #3 |
Newbie Join Date: Feb 2006 Location: Hesperia
Buy a HiTec 645 and just make a mount yourself...search here and youll find tons of info on it. You can replace it with the stocker or the HiTec 225 which is a direct bolt on but youll end up turning them into a pile of worthless plastic again in no time.
01-03-2009, 07:44 PM | #4 |
RC Axle Master Join Date: Mar 2008 Location: Las Vegas
Get the Hyperion HP-DS16FMD or Hp-DS16FCD there both a direct fit and plug right in. The FMD is metal the FCD is Plastic.
01-06-2009, 11:49 AM | #5 |
i ordered the Hyperion HP-DS16FMD .. i hope it does ok..its all metal so we'll see here is a link.. http://www.rcdude.com/servlet/the-11...l-Servo/Detail this is a great place to buy from. I ordered it on sunday at 5pm and my 5:30pm he already send a email with the tracking number..and shipped it in a half hour!ON SUNDAY! great service! Last edited by rccrawler66; 01-06-2009 at 11:52 AM. |
01-17-2009, 10:41 PM | #6 |
I picked up a Hitec HS-5245MG. It drops right in, just had to drill out the hole on the aluminum servo horn to fit a 3mm screw and away I went. Sure it's not a big power house but this thing Losi rig is a light weight rig.
01-17-2009, 10:44 PM | #7 |
Pebble Pounder Join Date: Aug 2008 Location: orlando
645hitech.... you won't regret it
01-17-2009, 11:44 PM | #8 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
in my past mini's I had issues blowing the small size servos. It seemed smart to just upgrade to a large 1/10th and cheaper too. As everyone mentioned a 645mg did the trick. If your worried about making a mount we did that for you too. Either option will work, just don't go back to the stock servo to save yourself the headache. http://rcbros.com/cart/Scripts/prodV...?idproduct=245 |
