01-09-2009, 12:10 AM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
| "The Flea" in the Boiler Room
I couldn't resist building up a tuber for my MRC, so a PM went off to DMG Jerry. Of course I need a spot to wheel it, and I'd go insane without crawling all winter; so I hauled some rocks into my basement. I plan on adding a bit more to the layout in the next few weeks, and I may replace the long stick bridge with a cable bridge. DMG Nat Tuber CR/CC Stainless Lower and Steering Links Eritex 1.9 Comp Heavies (No Added Weight) Losi 1.9 Blue Claws with Memory's Holmes Torque Master Mini Losi Metal Center Locker Tekin FXR Spektrum SR3500 Micro Rx Hi Tec 5245MG Digi Mini (Losi Horn) Losi 2S 600 mAH Lipo Losi CF Low CG Servo/Battery Plate Losi Threaded Shocks (80w Losi Oil with TCS Droop Springs) TCS Button Head Hardware Kit TCS Upper Link Plate MuchMore 18awg Wire and Micro Deans Fubar Crawlers Acrylic Rig Stand Overall Weight: 2lbs 7oz Overall Height: 4 3/4" Overall Length: 12 1/4" Track Width: 7 1/8" Wheelbase: 8 5/8" Belly Clearance: 1 3/8" Diff Clearance: 1 3/16" |
01-09-2009, 12:35 AM | #2 |
Rock Stacker Join Date: Nov 2008 Location: B-Town Crawlarado
Looks great! What is the set-up on your shock internal springs? weight of oil? |
01-09-2009, 01:15 AM | #3 |
Newbie Join Date: Dec 2008 Location: Woodstock
Man, that is SWEET. By far the best looking MRC I've seen. What plate are you using to get the servo and batt on on the front axle? |
01-09-2009, 05:10 AM | #4 |
Newbie Join Date: Nov 2008 Location: Bradenton
Agree with NDD, that is awesome!!
01-09-2009, 06:07 AM | #5 |
Newbie Join Date: Dec 2008 Location: SE MI
Love those stick bridges!
01-09-2009, 06:21 AM | #6 |
Quarry Creeper Join Date: Oct 2005 Location: Chattanooga
bige, from the original post Losi Threaded Shocks (80w Losi Oil with TCS Droop Spring NoDecoDiver, also from his original post Losi CF Low CG Servo/Battery Plate Like shootin' fish in a barrel, c'mon guys READ! But seriously Zorlac does incredible work, I just picked up a Snipe. I love the stealth look! -Lex |
01-09-2009, 08:11 AM | #7 | |
And thank you for the comments. After a bit more tweaking with the FXR, I also decided to move the rear shocks to the second mounting position to level out the rear links. I had to use an Associated ball stud shim to clear the shock cap; it just barely rubbed on the chassis tube. | |
01-09-2009, 08:27 AM | #8 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Great now I got to go some rocks and put them in my porch! My wife is gonna give that look like WTF?!?! nice ride and I love the bridge
01-09-2009, 08:32 AM | #9 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
A couple ??'s if you don't mind: The chassis looks like a straight swap with the stock suspension, is this the case? How much run time are you getting from only 600 mAH? Last edited by Big Mike; 01-09-2009 at 08:45 AM. | |
01-09-2009, 10:05 AM | #10 |
RCC Addict Join Date: Nov 2008 Location: never been
niiiiiiice, wanna swap with my SS/ jez kidding. liking the way you did your tuber, the best by far-kudos
01-09-2009, 10:16 AM | #11 |
Let me 3D Print that... Join Date: Jun 2007 Location: Concord
Very nice setup. I think that is my favorite DMG chassis for the MRC so far.
01-09-2009, 11:03 AM | #12 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
I think that is the thing that intrigues me the most about the MRC is that you can wheel it indoors with minimal space. Great looking rig.
01-09-2009, 07:06 PM | #13 | |
01-09-2009, 07:15 PM | #14 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
I have to have one of those chassis. Where can I buy one?
01-09-2009, 07:42 PM | #15 | |
Thank you for the comments...I appreciate them Quote:
Everything on the MRC is a direct bolt up for the Nat with the following two exceptions: If you want to run a flipped tranny, order yours without the ESC porch...the spur gear will not clear. It is also recommended that you run a shorter shock if you want to retain a sprung set up. Jerry used the Mini T Pro rear shocks all around, and I mocked mine up with the Losi Mini Late Model threaded shocks, but found them to be a bit too short. Otherwise, just droop the stock or threaded shocks. The only mod I had to make was to install an Associated ball stud shim under the rear ball studs to clear the shock cap from the tube once I had moved them to the outer hole. The threaded Losi shocks are just a tick longer than stock so keep that in mind, as well as the fact that if you run this chassis sprung with that length, you're CG and ride height are both increased substantialy. As far as run time on the Losi 600...I actualy don't know yet. I've only got a few minutes of testing on it so far. I'll post up that info as soon as I have it. And Jootz, you're little Sling Shot is sweet brutha' but I'm a tuber junky | |
01-09-2009, 07:44 PM | #16 |
| Here ya' go http://rccrawler.com/forum/showthrea...hlight=dmg+nat Just PM Jerry with your request. It will be a special order I believe, as he is currently fulfilling Snipe orders as well as 2.2 orders. |
01-10-2009, 01:43 AM | #17 |
01-17-2009, 09:36 PM | #18 |
Quick update on The Flea: Installed the Losi metal lockers in the axles. Losi CV Drive Shafts and Aluminum knuckles are on the way. Run time on the Losi 600 mAH Lipo right now is around 30 to 40 minutes on my indoor set up (not much heavy throttle involved here). 80w oil seems to work well with the droop set up, but I may try 100w just for kicks. I'm estimating that once I get some wheel time outside at our local hot spot this Spring, run time on the Lipo will go down...much gnarlier terrain. |
01-18-2009, 08:28 AM | #19 |
Rock Stacker Join Date: Oct 2008 Location: Richmond
I think that is the cleanest build I have seen yet. |
01-18-2009, 10:01 AM | #20 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
Sweet build and love the indoor course w/bridges, that should keep you from loosing your mind during the winter. Did you use Shoe Goo to make the bridges? |
