Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Rear Axel Output Shaft Getting Loose...
Old 01-12-2009, 08:40 PM   #1
Default Rear Axel Output Shaft Getting Loose...
As the title implies, my rear axel output shaft is developing some play. Not too much but more than the front. Seems to be one screw that holds it in.
My question is, should I crack the axel open to tighten the screw or just let it ride till something breaks? Is it worth the hassle? Anyone else have this problem?
I SMOKE ROCKS! is offline   Reply With Quote
