01-30-2009, 01:51 PM | #1 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
| Phenom - Limited's 09 Comp MRC - (pics & video) First off let me say thank you RCC for giving me a great place to get on and to clear my mind after a busy day at work. I was pretty excited the other day when someone on here excepted and offer on a trade of my spare Bully axles for a Losi MRC. I have been intrigued by the many builds on the Losi MRC forum, so much that I decided it was time to build one for myself. My goal here is to make a durable yet comp worthy rig. Here is the parts list: DNA: ASSASSIN 1.9 BEADLOCK LOSI MRC DNA: RC Mini Slingshot Chassis for Losi MRC TL: Mini Rock Claws TL: 1 Pc Rear Hub, Alum/Steel Axle Set TL: Front Carrier Set, Aluminum TL: Front Spindle Set, Alum TL: Front CV Driveshaft Set TL: Threaded Shock Set, Aluminum w/Ti Shaft TL: Mini Grappler HR: MRC1000T Hard Anodizing Alum. Center Gear set. HR: MRC25X08 Alum. diff posi lock spool kit x2 HR: MRC10W08 Aluminum Wide wheel hex MRC HOLMES: TorqueMaster Mini HITEC: HS-645MG TEKIN: FXR Spektrum: DX3R Last edited by limited77; 02-08-2009 at 07:53 PM. Reason: informational |
01-30-2009, 02:14 PM | #2 |
Stock lockers vs. HR lockers Stock plastic lockers. HR lockers installed and all plastic internals removed. Btw I had no issues removing the tiny hardware. Here is a picture of the HR lockers seperated from their packaging. Last edited by limited77; 01-30-2009 at 02:29 PM. |
01-30-2009, 05:34 PM | #3 |
Here is a couple of pictures comparing the stock hex to the HR aluminum hex. The kit also comes with pins and set screws. The set screws are always a nice addition; no more loosing pins. These will add approximately 1/4" overall. |
01-30-2009, 05:40 PM | #4 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
looks like a really good start, subscribed to check progress |
01-30-2009, 06:00 PM | #5 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
You are using alot of the parts that are on my wish list, looking forward to watching this and seeing how it turns out.
01-31-2009, 05:26 PM | #6 |
So, I took my wife out for dinner and a movie (Underworld: Rise of the Lycans) today. If you have seen the other two you basically already know the whole story. We just got home and bam! 3 packages at my door. It really wasn't a surprise I was expecting them. Now that I am home I am going to try to finish as much as I can tonight so I can do a little testing tomorrow. |
01-31-2009, 05:57 PM | #7 |
Here are the CVD's with the shrink rap mod. |
01-31-2009, 06:04 PM | #8 |
Pebble Pounder Join Date: Dec 2007 Location: Tucson, AZ
lookin good so far
01-31-2009, 06:13 PM | #9 |
now its time to open all those pretty packs and start getting your hands dirty |
02-01-2009, 01:35 AM | #10 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Man nice stuff,you are going to have 1/2 the truck left but it will be bullet proof |
02-01-2009, 02:29 AM | #11 |
Quarry Creeper Join Date: Jun 2007 Location: Waipahu
That's alot of great parts!
02-02-2009, 07:17 AM | #12 |
My first oberservatios: 1) These shocks are not that great fit for this chassis; looks like i'm gonna just have to build a mini GC-2 also . You have to llimit them to the point where they are useless or possibly go with a droop setup. I have some TL mini t shocks on the way to replace these with. 2) My main issue so far is the tiny hardware that holds the lower links on. The first time I had the mini out I broke one of the screws off up in the skid from a 2 foot fall landing squarely on all fours. Remedy: 2mm steel rod. Last edited by limited77; 02-07-2009 at 07:23 PM. |
02-02-2009, 12:20 PM | #13 |
RCC Addict Join Date: Nov 2007 Location: somewhere
02-04-2009, 08:23 PM | #14 |
| Me no comprende! Anyways here is the specs of the new Maxamps 2S 1290mah lipo I am installing in my MRC's. Notice it is basically the same size as the 860 just slightly thicker.
02-04-2009, 09:49 PM | #15 |
[quote=limited77;1601892]Me no comprende! u sh0uld have built the mini gc2 t0 start with l0l |
02-07-2009, 09:03 AM | #16 |
I fixxed several issues. I'll have some pics up later today.
02-07-2009, 09:19 AM | #17 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
that mini slingshot is a great little rig. i just started a build with minilst rears and fit seems good. almost have a roller done seems to go together pretty easy. about like the 2.2 . ill keep chacking back for updates.
02-07-2009, 07:47 PM | #18 |
Here are the updated pics as promised. New skid from DNA. I used 2mm steel rod and tubing between the lower link rod ends. I installed mini t rear shock with soft springs in the front and soft/medium in the rear. Ride height is at 2 1/8". Servo crowned by Reign. I tried to go clean as possible. Some 5/16 fuel line and a pair of scissors. Last edited by limited77; 02-08-2009 at 10:27 AM. Reason: update information |
02-07-2009, 08:41 PM | #19 |
Some more pics with a freshly painted mini grappler. |
02-07-2009, 08:48 PM | #20 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
Nice build |
