02-07-2009, 07:20 PM | #1 |
Newbie Join Date: Jan 2009 Location: Twinsburg
| Better Traction Help
Just Starting in to this, having a blast My Brother has been helping me along but I have the Losi MRC. I am Having a problem with traction I can hit about 60 degrees on the incline board. Stock configuration it was about 45. The mods I have made include moving the battery up front building new plates and moving the electronics down. I also have tried lighter springs from mini lst rear shocks, up front that helped some of the torque twist up front. Looking for any mods to make to the stock wheels, and how much weight I could add before things get to to the point of overload and over heating to improve traction.
02-07-2009, 07:42 PM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: Ukiah
have you tried new tires or wheels with weights?
02-07-2009, 09:36 PM | #3 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
You can safely add a few ounces to each wheel but you will notice WAY better traction if you switch to a comp type tire like the blue claws or G8 compound flatirons (that's what I run on mine) and the difference is night and day! (I have weight in the fronts only) About 2.5 or 3 oz's.
02-08-2009, 09:04 AM | #4 |
trying to avoid buying new tires and wheels right now. Going to try adding the couple of ounces of weight today and see what happens. Trying to stay in a small budget.
02-08-2009, 09:17 AM | #5 |
Newbie Join Date: Feb 2009 Location: Goodwood
try lead ballsin the front if you have bead locks
02-08-2009, 09:26 AM | #6 |
Rock Crawler Join Date: May 2007 Location: Glendora
I have loaded my MRC with all the Losi goodies and relocated the electrics. I ran the stock tires and rims with no weights and the suspension at stock height....it was too high for me and twisted too much. I changed my Losi threaded shock set up to 40wt in three shocks and 50wt in the right rear to fight the torque twist. I also limited the shock travel internally with some fuel tubing (about 3/8 inch). I noticed a BIG inmprovement in traction and capability still running the stock tires and rims with no weights!!! I cannot wait for my Eritex 1.9 COMP HEAVY rims to come in so that I can mount up the BLUE Claws!!! ....I expect traction to be even better.
02-08-2009, 09:45 AM | #7 | |
RCC Addict Join Date: Jun 2008 Location: Wasilla
- Tre | |
02-08-2009, 06:17 PM | #8 | |
02-08-2009, 08:54 PM | #9 |
found the dyi thread for bead locks, also added some weight this afternoon still at 60 but doing it much easier less slipping. just going to have to break down for new tires.
