04-07-2009, 09:45 PM | #1 |
Newbie Join Date: Feb 2009 Location: graham
| Oops!!
broke the mini today...broke the center locker and a gear in the tranny as well...are the HR aluminum gears okay for replacement?
04-07-2009, 09:48 PM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: Ukiah
pretty sure theyre direct replacement
04-07-2009, 09:50 PM | #3 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
Haven't broke either of mine yet! Gatta replace a steering servo though... Would think steel would be less prone to strip... Especially w/ yer High Falutin' motor yer runnin... Dont think I've seen steel gears yet unfortunately... Bet I can school you, gots the rear steer action... :-P
04-08-2009, 04:52 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: searching
i got the hr center spool + gears & spur gear i added white lithium grease for lube. so far no troubles. when i installed these i failed to realise my slipper was stuck but i think it was stuck before as id never heard it slip. after complaining about broke frt cvd's on here i got set straight, now it works too!!! properly operating slipper = less/no broke parts
04-08-2009, 08:44 PM | #5 |
well my normal supplier is out of the aluminum gears...so i got some stock plastic gears and a new center metal locker....i dont think my slipper was working at all...but it will when i re-assemble the thing...
04-08-2009, 09:07 PM | #6 |
I installed my Losi metal center locker today. It was a PITA to get the halves into the plastic gear because the fit was so tight! I had to "pound" them into place. I only have red thread locker so I didn't use any. |
04-09-2009, 09:14 PM | #7 |
got my parts today....mabye tomorrow ill put it back together...
