04-10-2009, 09:34 AM | #1 |
Newbie Join Date: Apr 2009 Location: Northampton
| newbie
Hey guys just got mrc 2day anything i should look out for as far as problems and whatnot also anything i should to prevent said problems thanx i cant wait to take this thing out |
04-10-2009, 10:01 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: ON THE ROCKS
replace the lockes with metal and new tires
04-10-2009, 11:38 AM | #3 |
Rock Stacker Join Date: Mar 2009 Location: SC
watch the pins in your drive shaft they like to fall out
04-10-2009, 11:45 AM | #4 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
welcome to the wonderful world of rock crawling have fun with your mini
04-10-2009, 12:07 PM | #5 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Replace front and rear lockers with either the hot racing ones or rcbros to get rid of all the plastic in the axle diffs. Might get a metal center diff, the stock one lasts pretty long so it can wait. Mount everything as low as you can, add weight to the wheels. Lower it and limit the articulation.
04-10-2009, 01:22 PM | #6 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
Run it till it breaks upgrade repeat. Get to know it see what you like see what you want to change...
04-10-2009, 02:42 PM | #7 |
Newbie Join Date: Mar 2009 Location: st george
you need to watch out for the addiction! you have been warned. |
04-10-2009, 03:45 PM | #8 |
ok thanx guys just took it out runs great no problems yet but il definitely look into these things |
04-10-2009, 06:02 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
I cant believe no-one has mentioned this yet. Shock Oil. Immediatly. It only cost about 3-4 dollars a bottle, and is extremly easy to change. (there are even instuctions in the owner manual) I would recommend at least 50wt, tho some like it stonger (i.e. 60-70-80) and some like it weaker (i.e. 45-40-35) Its all a prefrence thing, and its so cheap and easy to do, you can try mutliple weights for very little cost. |
