04-16-2009, 09:14 AM | #1 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
| [A few] MRC Questions/Comments
Hey all; great 'site! The reading I've been doing here the last few weeks has been quite educational: until this week, my only experience is with RC "toys" as an adolescent, so the knowledge base here is very helpful for me. After getting my MRC and doing a bit o' stock crawling, I've a few questions motivated from my observations of my new rig that don't seem to be directly answered here (implied probably, but some of this info is a bit confusing for me still). I've front/rear lockers on the way from RCBros, but that's all so far. -the MRC manual suggests on one page that the shocks are prefilled with 30wt oil; on another page it reads 100wt. The shocks seem quite slow to react, so I'm guessing it's 100wt? (I've no basis for actual comparison - just my rig and lots of videos. But I'll try some 50wt from the LHS when payday comes.) In retrospect, they may have felt a bit tighter right out of the box, as opposed to after the first good crawl. Is there a break-in period or is it in my head? -I flipped my tranny, battery tray, and was going to mount the battery on the servo, but after doing more reading to make sure I did it correctly (it seemed too easy) I found a minor debate about "postive timing" and the possibility of damaging the stock MRC motor running it backwards. Are the risks a real possibility to consider, or is damage inconsistent enough to justify the benefits? (A motor upgrade may be down the road, but is not first on my list.) Admittedly, I grew concerned after reading about this so I returned it to stock form for now. I was going to mount the battery on the servo anyway, but the wiring is too short; so rather than just splice and make the leads longer, it's probably prudent to add some Deans connectors while I'm at it? (I have yet to research the Deans concept, but it seems that they're popular connectors that ultimately make upgrading electronics/wiring easier to mess with in the long run?) -My reading and observations of the stock tires/foam suggest that the stock foams are a bit hard(?). The tires felt kind of squishy in my hands but on the rocks it seems like the tires would benefit from "more give." Softer foam, yes? ...I didn't think they were, but some of my rocks, I guess, are on the slippery side, so I'm thinking Blue Claws and budget Axial bead locks for now. -I'll get to a sporting goods store for some weight, but for now I'm curious about those running steel/airsoft BB's in their tires. The stock foam seems rather big in the stock tires - are the BB's placed between the foam and rubber, between the foam and rim like the "lead rope," or are the BB's taking place of the foam? I suppose this is enough for now! If you've read this far, I appreciate the effort! Again, great site. Thanks. |
04-16-2009, 09:23 AM | #2 |
Newbie Join Date: Apr 2009 Location: HAVELOCK NC
i just tore one of my extra wheels apart (to learn) and yea the foam will not allow the bbs to rol around like ya want. i pulled the foam out and the wheels are VERY soft. in my opnion id say go with the lead rope. then you can up grade your foam and what not and you dont have bbs to deal with just my 2 cents |
04-16-2009, 09:35 AM | #3 | |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
04-16-2009, 12:36 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: searching
as for your esc,you could make a tray on the frt. three link connector(the upper susp. link) & mount esc there,its tight but it will fit.then your bat can set on top of servo. no wire splicing necessary |
04-16-2009, 01:26 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
RcBros pretty much answered your questions. But I just wanted to add to your question about tranny flip. I did the flip but I run a HH mini torquemaster which has 0 timing, I only did this for clearance. I see no other real benefit like a AX10 tranny flip.
04-17-2009, 09:42 AM | #6 |
Great info - thanks!
04-30-2009, 02:03 PM | #7 |
For the stock tires I ended up adding some flattened lead rope around the rims which added 1.5oz each tire; and, in the end I found that empty tires ran better than the stock foam on the [new!] rock garden in the backyard. I also added 1.5oz to the front axle and moved the battery to the top of the servo - just these things really improved COG and climbing ability. But...I ended up getting some Blue Claws and Axial bead locks. The bead lock mod for the stock tires was "ok" - but these Axials seem to hold a bead pretty nicely. I've yet to get 'em on the rocks, but the compound of the Blues sure is a lot stickier than the original tires. That'll be good on my slippery locks, I hope. I'm looking forward to trying some G8 Flats, too. I added a Castle BEC and wired it up with Deans. Running the MRC around a bit this morning, the ESC still got a little warm (though not as much as usual, I think) and the CCBEC got a little warm, too (but certainly not uncomfortably warm to the touch). There's current flowing, so I'm hoping the CCBEC warming up a little is normal? (It's all wired per the Castle diagram.) A HiTec servo is on the list, so I'll be ready for that... I also made up a ghetto four-link plate for the rear just for kicks (I don't have a shop equipped enough to make a nice plate; so I'll get an aftermarket four-link from someone online). For clearance I had to move the shocks outboard, and I moved the links inside the chassis. In my limited experience, it seems to have helped with the torque twist, but it's not as "loose" (as the original three-link) when moving the axle back and forth with my hands. It seems to have decent articulation, it just seems to take a hair more muscle to manually move it to and fro. Is that normal, too? Please feel free to advise, criticize, or comment as you feel! |
05-01-2009, 08:39 AM | #8 | |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Cheers | |
05-03-2009, 10:20 AM | #9 |
Yep; front and rear lockers were actually the first thing I ordered from RCBros. I really like the Blue Claws. The first battery pack I ran with them, I was very impressed - super sticky. I rinsed off the dirty tires for the second battery pack and they still did very well, but they weren't quite as sticky as they were fresh out of the packaging. I'll try some Simple Green... Hands down, though, these Blue Claws totally outperform the stock tires. I'm making lines in my little rock garden that I couldn't make before. In fact, I'm going to have to complicate the garden a bit, as these tires really perform. It rained the other day and though the Blue Claws did well, the added slick did make them slip a little more, of course... G8 Flatties will be my next tire purchase, I think. I assumed that the CCBEC should be plugged into the MRC's RX's auxillary plug and ran it that way for two batt' packs, but then found some posts that suggest plugging it into the "Battery" plug; the MRC's RX "options" are AUX and BIND. The rig works with the CCBEC in either plug - does it really matter? Maybe if/when I want to utilize the 3rd RX channel, it will matter...? My rear ghetto-four link isn't binding in the rear; though I did mount the links on top of the four link plate, rather than below as I've just noticed in many pictures. I think it changed some geometry up front(?), as I recently noticed that the stock battery on the servo rubs the body at/near full flex. Maybe I didn't notice it before--when everything else was still in stock position--but I don't think so. |
