04-18-2009, 12:26 PM | #1 |
Newbie Join Date: Mar 2009 Location: Corona
| Binding of factory Losi RX/TX issues
Hey guys, I've been having a consistant issue with my factory Losi 2.4 RX/TX setup. Anytime I wanna run the MRC, I have to first rebind the radio gear. Sometimes, even when following the binding instructions(it's not rocket science by any means.) it just will not rebind.:-( Just wondering if anybody else is having or has had this issue. I always unplug the battery from the ESC before I put it away. Could this be the problem? Thanks for your help in advance `Mouse |
04-18-2009, 12:41 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
new batteries in the reciever clears up 99 percent of the problems people have with this
04-18-2009, 12:44 PM | #3 |
04-18-2009, 01:03 PM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Are you turning the transmitter on first?
04-18-2009, 07:13 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
04-19-2009, 01:44 PM | #6 | |
I use these in all of my radios: And for the above question, i turn the vehicle on first as per the instruction manual. Most of the time, i will have to do the bind process several times before it actually binds. What would / could cause interferrance that could possibly be hanging up the connection? Could it possibly come "unbound" from extended periods of none use? I dont always have alot of time to run the MRC so it does sit for a few days from time to time. Everything is factory stock on my MRC with the exception of Deans Ultra connectors. I also have two other vehicles that use Spektrum radio gear and i have never had to rebind them Last edited by Mouse; 04-19-2009 at 01:47 PM. | |
