Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Motor Going Bad???
Old 05-08-2009, 11:40 PM   #1
Default Motor Going Bad???
I just put lipo on my MRC today. I ran it for a little while and had no problems. Torque like crazy!!! After running it for a while I came into a situation where my tires got bound up and when i hit the throttle it sounds like the motor is spinning but the tires arent. Does fine until it gets in a bad bind now? Any ideas??????
nightcrawler86 is offline   Reply With Quote
Old 05-08-2009, 11:48 PM   #2
Sounds like your slipper clutch is loose. Pull off the gear cover and tighten it clockwise.
Shaun is offline   Reply With Quote
Old 05-09-2009, 03:44 PM   #3
pup
Yep, mine did not slip until a motor change also. You can tighten it up a little but be aware you will more than likely start breaking diff and transmission lockers next if you have not upgraded them.
pup is offline   Reply With Quote
