Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: My MRC build
Old 05-10-2009, 12:57 AM   #1
Default My MRC build
Here is my MRC.
Mods I have made include throwing out the radio tray
reversing the transmission
Mini T shocks on the rear(stock up front)
Custom machined 3 piece beadlocks
Blue compound Rock Bashers
Reedy 19 turn Mod motor
Castle Sidewinder Micro and BEC
JR St126 metal gear servo, I used an axial servo mount plate drilled for the losi axle
Custom body mounts
2-cell lipo mounted to upper front links
metal diff/trans lockers
better pics to come
4VRYNG is offline   Reply With Quote
Old 05-10-2009, 01:47 AM   #2
Looks good so far. Any plans for an aftermarket chassis or more upgrades?
jnev is offline   Reply With Quote
Old 05-10-2009, 02:02 AM   #3
I am planning on some better shocks, not sure about a new chassis, this thing actually works very well the way it is and I don't know if I want to start messing around with a chassis right now, maybe after our points series is over for the year.
I am going to put the bent lower links on for sure and the aluminum steering knuckles. I also want to upgrade the plastic steering linkage and servo horn. Would like to upgrade to the MIP cvd drivelines. Also looking for metal trans gears.
Here are a couple of better pics as well. Shows my nearly flush body mounts. and my brass weights for the front wheels.
Old 05-10-2009, 10:39 AM   #4
Why min i t springs on the rear? what does that do?
nightcrawler86 is offline   Reply With Quote
Old 05-10-2009, 11:41 AM   #5
I broke the ball cup on a stock shock and I had the mini-t piggybacks sitting there so I tried them, it dropped the stance in the rear a bit and limited the articulation of the rear. It just happened to work really well so I have not changed it.
Old 05-10-2009, 12:20 PM   #6
Your Esc is Toast!
crawladan is offline   Reply With Quote
Old 05-10-2009, 10:14 PM   #7
What do you mean by esc is toast?
Old 05-10-2009, 10:44 PM   #8
Stock esc+lipo= bad news id suggest picking an fxr up so you dont have to go through the heart break of esc failure
Old 05-10-2009, 11:18 PM   #9
i have been running lipo on my stock esc for a little while now.
Old 05-10-2009, 11:19 PM   #10
Originally Posted by crawladan View Post
Your Esc is Toast!
??? What??? I am running a Sidewinder Micro, not the stock esc.
Old 05-10-2009, 11:20 PM   #11
Theres nothing wrong with running a lipo on the stock ESC, I and several other guys I crawl with are doing it without a problem.
Shaun is offline   Reply With Quote
Old 05-11-2009, 05:44 PM   #12
i ran 2s lipo and HH torquemaster+ full size servo my esc is completley dead
