| View Poll Results: Where are you running your battery? | |||
| Front | | 38 | 66.67% |
| Rear | | 19 | 33.33% |
| Voters: 57. You may not vote on this poll | |||
| | #1 |
| "HOLLYWOOD" ![]() Join Date: Dec 2008 Location: Miami
| So which do you perfer or are running? |
| Sponsored Links | |
| | #2 |
| Team T1E/VP Driver ![]() Join Date: Feb 2008 Location: High Point
| I put mine on the front upper control arms... get the weight to the front, but keep it low too! |
| | #3 |
| Pebble Pounder Join Date: Sep 2008 Location: Anniston
| I have mine on the rear axle but simply because I dont have room on the front servo because of the way I have my body slammed. |
| | #4 |
| I wanna be Dave Join Date: Jun 2005 Location: With my family
| I'm running mine on the rear upper link. I didn't flip the tranny and I have a full size servo so there was no way to get it up front. I put the esc and BEC up front instead. |
| | #5 |
| Team Nylint ![]() Join Date: Jul 2006 Location: Elberfeld
| I always run my battery up front. On my Evo, I'm running my new battery on the upper links. With my older battery, I ran in on top of the servo. |
| | #6 |
| Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
| Like some others here, I dint have tranny flipped cause of the Darksoul chassis mounting doesn't allow of that. So i'm running battery on rear upper links. |
| | #7 |
| DOOH!!! ![]() Join Date: Feb 2007 Location: *
| | #8 |
| | #9 |
| %@$# ![]() Join Date: Feb 2009 Location: Milwaukee
| Also the rear upper links, 645mg & full weights on the rims up front keep everything "even-d out" |
| | #10 |
| Quarry Creeper ![]() Join Date: Mar 2009 Location: searching
| i got my thunder power 1320mah mounted on the servo, works good for me so far |
| | #11 |
| Rock Crawler Join Date: Mar 2009 Location: Cottontown
| split, 2 cells on each front corner, with 2 in center of chassis |
| | #12 |
| Am gonna be going with vanquish 1.9 comps. so were I put my battery is very important. |
| | #13 |
| Pebble Pounder Join Date: Jun 2007 Location: Clackamas,Oregon
| Flipped tranny, full size servo and still stuffed a 1350mah 2-cell lipo on front upper links. |
| | #14 |
| If your getting a front 4 link/servo plate, most of em have room for either electronics on the plate, or batteries. I'm going with batteries on mine, 2 cells each side, and will either mount the other 2 center, or on the rear axle. Depends on where I can fit the electronics. |
| | #15 |
| Quarry Creeper Join Date: Mar 2009 Location: ON THE ROCKS
| i have my electronics on the 3links and my batt on the rear that may change when i get my mixer chassis |
| | #16 |
| made bracket to mount up front behind servo. gonna be mounting the reciver on rear four link. |
| | #17 |
| Rock Crawler ![]() Join Date: Nov 2005 Location: Rock-throwing country
| Up front for me! A 600 mah 2cell lipo fits well! |
| | #18 |
| Good thing is the battery's I have are small and thin got 2 500 lipo's from flight check and 2 stock battery's, the stock battery's what am a little worried about were I place them. |
| | #19 |
| I weighed my esc and my batteries last night and the esc weighs more so I think having it up front is bettery in my situation. I am only running a 900mah 2s lipo but I am using an old Rooster crawler I had laying arround. I know I know that thing is huge, but it has lipo cutoff built in and I don't care enough about the 1.9 to spend $100 on an FXR for it. Last edited by bigflex; 05-19-2009 at 09:01 AM. |
| | #20 |
| Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
| Split pack, 3 cells next to the servo and 3 cells on front upper links. |
| Thread Tools | |
| Display Modes | |
