Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: micro mongoose?
Old 05-17-2009, 04:45 PM   #1
Default micro mongoose? with 3s lipo?
Does anyone have the micro mongoose in their mini crawler?
Is anyone running a full size servo with a 3s lipo?
Would a 2 or 3s lipo be better?
rockmahala is offline   Reply With Quote
Old 05-17-2009, 05:05 PM   #2
Power of the Portals
I been running one in my mini since ECC and no problems. The best upgrade I have done yet!
eric113 is online now   Reply With Quote
Old 05-17-2009, 05:07 PM   #3
rcjunky3's Avatar
been really happy with mine
rcjunky3 is offline   Reply With Quote
Old 05-17-2009, 05:21 PM   #4
LIKES2CRAWL's Avatar
Any videos? How's the wheelspeed and what gearing you running?
LIKES2CRAWL is offline   Reply With Quote
Old 05-17-2009, 05:26 PM   #5
Is the internal BEC powerful enough to run a full size servo?
jnev is offline   Reply With Quote
Old 05-17-2009, 08:50 PM   #6
rcjunky3's Avatar
stock novak pinion i dont think the wheelspeed is as insane as the slider motor i had with stock esc. i am not running a full size servo ive got a hitec mini
Old 05-17-2009, 09:37 PM   #7
is anyone running a full size servo with their mongoose?
Old 05-18-2009, 06:27 AM   #8
I have this in mine and really like it. (of course I ripped apart a ring and pinion gear with it the first comp I ran it )
I am running a full size servo of it with no problem at all.
swisherteets is offline   Reply With Quote
Old 05-18-2009, 06:32 AM   #9
Im running it, with a full size servo, and a 2s lipo and the wheel speed is more then enough. The torque is great too, I ended up having to upgrade to the aluminum lockers because I stripped the stock ones.
microdot is offline   Reply With Quote
Old 05-18-2009, 06:40 AM   #10
I'm running one in mine. I also run a full size servo the JR 9100T. Running the Losi lipo 600mah and had to get an external BEC. Works great!
T.T. is offline   Reply With Quote
Old 05-18-2009, 10:32 AM   #11
fordwheeler's Avatar
i got one in mine w/a hitec 985mg & i love it. it has a 6v 2amp bec in the esc, but i added a 6v 5amp external bec,not sure if i really needed it though
fordwheeler is offline   Reply With Quote
Old 05-19-2009, 10:53 PM   #12
im running a full size in mine with a 2s lipo on the front three link and on carpet it will do a whiles in forward and reverse.
I love mine it is very predictable...
Jason S is offline   Reply With Quote
Old 05-19-2009, 11:24 PM   #13
Talking
thanks guys i just wanted to see what you guys thought of the system, i got mine on the way and need to install it.
Old 05-22-2009, 03:26 AM   #14
I running a Novak and love it three cells way too much and is not legal for comp's I am also running a bec for safety no trouble with a full size servo. hope this helps.
Dxxcrawler is offline   Reply With Quote
Old 07-01-2009, 01:51 AM   #15
RCCrawler
Default Overheating
I'm running the mongoose setup in my MRC. And have the full size servo. I'm having thermal shutdown problems. Any suggestions? Also running a 3 cell.
fa1rch1ld is offline   Reply With Quote
Old 07-01-2009, 03:10 PM   #16
Suggest you send a complete, detailed description of your entire setup to tech@teamnovak.com.
Please include all info in your initial email---
specific Novak components installed,
battery type (C rating capacity mAH),
external bec (?),
servo brand,
receiver, etc.
The more details you include in your email, the quicker they will be able to assist you. Otherwise, you could be playing "email tag".
NovakTwo is online now   Reply With Quote
Old 07-01-2009, 06:04 PM   #17
RCCrawler
I think the problem was I'm not running a BEC. I just got a castle creations one. Im going to set it to 6V and 5 Amps. See if that will fix the problem.
Old 07-01-2009, 06:53 PM   #18
TCS/Holmes Hobbies
SVEN's Avatar
Video with a Novak Mongoose.
The Zero MRC
SVEN is offline   Reply With Quote
Old 07-02-2009, 11:24 AM   #19
RCCrawler
the bec worked great. set it at 6v.
Old 07-02-2009, 05:32 PM   #20
i am running the mongoose with a 2s 1500 and a hitec 5645 no problems so far as long as i don't try to crawl when temp is over 105 cuz then i have thermal problems with crawler and my brain
joe daigle jr is offline   Reply With Quote
