| | #1 |
| Rock Stacker Join Date: May 2009 Location: Desert
| Hi im new to the crawler seen been working on a scaler. Well my question is i ran my crawler through some really thick mud (like a dumbass!!) and well now my left rear tire gets all the power in the rear instead of both getting same amount. What could be the problem? thank you!! Last edited by speedcrawler; 05-19-2009 at 10:43 PM. Reason: misspelled |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Feb 2009 Location: Wisconsin
| busted locker?? that would be my guess. |
| | #3 |
| Quarry Creeper Join Date: Feb 2009 Location: Conowingo, Maryland
| you need aluminum lockers from RCBROS.com that should fix your problem |
| | #4 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| Pull the rear axle apart first and make sure the heads of the diff screws weren't snapped off also. You need a 1.5mm and 2mm allen wrench and a 7mm socket(the largest one on the 4 way) to pull it apart. |
| | #5 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| The stock lockers are just not worth it....IMO Last edited by constantmotion; 05-20-2009 at 11:00 AM. |
| | #6 |
| Rock Crawler Join Date: Mar 2009 Location: Visalia, CA
| | #7 |
| Quarry Creeper ![]() Join Date: Jul 2008 Location: Asheboro N.C
| If you haven't taken it apart it could also be the axle shaft, but I would go ahead and upgrade to RcBros metal lockers |
| | #8 |
| Newbie Join Date: Mar 2009 Location: Showlow
| I broke both front and rear lockers on mine (the stock one's are junk), and my wheels did the same thing. Losi makes a metal locker upgrade, I replaced mine with them and so far I haven't been able to break them. |
| | #9 |
| Pebble Pounder Join Date: Apr 2009 Location: West Monroe
| same here busted the locker and same thing happend also busted my center lockers in the transmission also recommend the metal ones from losi for the transmission |
| | #10 |
| I like to #*&^ ![]() Join Date: Mar 2009 Location: sittin in the sky
| | #11 |
| umm i think for all the lockers through losi i gave like 45 or so dollars give or take you need 2 sets of axle lockers and one set of center locker |
| | #12 |
| They're not expensive. $10-12/axle. If money is tight, do the front/rear, first, the center, later. I went with the RCBros front/year lockers. |
| | #13 |
| i got the lockers but i stripped one of the screws |
| | #14 |
| That's the thing that you have to lear about plastic and that is when tight is tight. |
| Thread Tools | |
| Display Modes | |
