| | #1 |
| Rock Stacker Join Date: May 2009 Location: Desert
| Just got a mrc and want to make it comp ready What should I look into and what will Make the biggest improvement? Thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
| tires wheel weight low cg practice getting rid of the torque twist a few idea off the top of my head, biggest thing is knowing what your rig is capable of. Search around and you can find just about anything on here. |
| | #3 |
| Rock Crawler Join Date: Mar 2009 Location: Cottontown
| If you want to make it comp ready, and also competative heres what you are gonna need. metal lockers (front/rear/center) quality shocks (RcBros or Losi, or another quality threaded body alum. shock) and your choice of shock oil, I'd reccomend 50wt. Wheels and tires. Good, true beadlock wheels, and good tires. (I like the G8 flat irons from proline, others like the losi blue claws or bashers. Your choice really, just check around to make sure you get what you want). new chassis. (There are so many out there to choose from. Spend some time looking through all the build-ups on here to help you decide what you want. 4 link setup front and rear (some chassis kits come with 4 link plates, some dont. If the chassis you want doesnt come with the 4 link plates then its something your gonna have to get) servo (Most people seem to be in agreement that the hitch 645 is the way to go) Electronic Speed Controler (ESC). Most people are using the Tekin FXR or the Tekin B1R. There are lots out there, so read up. Motor. You can stay with the stocker if you want, its not that bad. For that extra torque tho your gonna want a better motor. Most people will suggest the Holmes Hobbies Mini Torque Master. Its a great motor at a great price. Wheel weights. Your choice about how much to use here. Try diffrent amounts and see what you like. Other than those things, its mainly the way you set it up. You can switch to LiPo's if you want. They're great. But for the short amount of time your actually crawling in a comp I dont think it matters. And you might want to fiddle with the gearing a bit. Once you get these things, its just a matter of test and tune, and lots of practice. Guys, did I miss anything? |
| | #4 |
| thanks guys sounds good just got to find the stuff and get the money up |
| | #5 |
| "HOLLYWOOD" ![]() Join Date: Dec 2008 Location: Miami
| Another very easy way to find things is usually some will post that they are building a comp rig, so when you see a thread with comp build on it or building comp ready MRC, you may want to look in there. |
| | #6 |
| I like to #*&^ ![]() Join Date: Mar 2009 Location: sittin in the sky
| how are you guys mounting the battrey down low? |
| | #7 |
| Pebble Pounder Join Date: Apr 2009 Location: West Monroe
| I have mine across the back axle or if you look around i think common sense batters have some you can get them small enough to sit on your 3 link |
| | #8 |
| New Papa! ![]() Join Date: Dec 2008 Location: With the ATL Crawlers
| I assume that your starting with a out of the box losi. If so, I'd start by limiting your stocks by at least a 1/4in. Play around with shock oil to find a good feel. Make a upper link mounting plate for your electronics. Get some velcro and mount your battery on top of your servo. If you got a little extra cash go ahead and get some blue labels(claws) and a 645mg servo. For bead locks, do the pvc trick to your wheels and add weight while your there. I did these little tricks and practiced and took 5th place at my first comp. |
| | #9 |
| Rock Stacker Join Date: Nov 2008 Location: Bismarck
| Remove battery tray, mounted speed control on tranny with velcro as low as i could, receicer on front link, battery on rear axle, put on losi blue bashers, add wheel weights, limit shocks and practice. This is what i did for my first comp and took 2nd, the first place guy had bigger tires than the bashers different motor and it was weighted down more than mine, and he had more crawling time under his belt. |
| | #10 |
| Rock Stacker Join Date: Sep 2005 Location: Fairmont (but always from Flagstaff AZ)
| i agree with zr600, keep it cheap and simple and just drive that way when you find out what you think needs to be better then do that mod. you will enjoy the mod more and then stay in the sport longer too. tires and weight and move stuff around to fit your needs. i am just a basher and love the little MRC along with my others. have fun and challenge yourself |
| | #11 |
| Quarry Creeper Join Date: Apr 2008 Location: Clay, Alabama
| lots of recommendations to put the battery over the rear axle... I thought the idea was to get all of the weight you can toward the front... is that not correct for the smaller rigs? |
| | #12 |
| I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| Yes this is correct, but most are running a small lipo and they weigh next to nothing. I have fully loaded Losi alum. beadlocks with a little extra weight then the bolt on ones up front, no weights in rear, have my BR1 esc up front just above my upper links on the chassis, I have a Holmes Hobbies 1300mah 2cell lipo mounted on the side of chassis opposite of motor to help balance out side to side weight and my rec is on my upper rear link mount. It;s a little front heavy but all the weight is prety low. |
| | #13 |
| ITS TOO CLEAN...MORE MUD ![]() Join Date: Jul 2009 Location: abq
| i went with a with tamiya touring car shocks off an old kit with 50wt oil and no springs. It is a temporary set up but it lowers the CG a whole bunch compared to the stock shocks. Just make shure you have a skid plate on the bottom that slides easily as you will slide on it alot. I to am getting into the sport and some may not agree on my tip but it works for me. Good luck |
| | #14 |
| Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
| heres my tips! nice beadlocks good tires metal tooth servo clean stuff screw everthing else, the MRC comes with great electronics, the servo stock is the only bad part, ive went through 4 so far, but make it as high as u can, if u lower it u cant crawler up stuff for shit LOL its true |
| | #15 |
| metal lockers all around Full droop setup losi blue claws full size servo lipo added weight Im going to get my aluminum shocks today and ill probably get some flat irons soon. Thanks for all your help guys |
| | #16 | |
Droop rocks. and thats true. | |
| | #17 |
| RCC Addict ![]() Join Date: Apr 2008 Location: Old Hickory
| Im going to get my aluminum shocks today and ill probably get some flat irons soon. Thanks for all your help guys I vote no to the flat Irons if you want to run a taller tire then the blue claws grap some 2.2's and cut and shut em! I switched from FI's to chisels and will never go back to the FI"S |
| | #18 |
| I want to cut and shut some tires but I don't want to mess up lol |
| | #19 |
| I hear ya! I'm still chicken too! I would try the panther cobras if I was gonna give it a shot! Oh and Gatekeeper runs losi blue claws if that tells ya anything. |
| | #20 |
| Does any one know what the best tire for dirt that's loose?? Where I cawler there's alot of it. Also what's the beat way to crawler sideways I always flip mine when I try crawling sideways |
| Thread Tools | |
| Display Modes | |
