Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Losi Mini-Rock Crawler
Thread: Losi Aluminim Beadlocks
Old 05-20-2009, 08:00 AM   #1
Default Losi Aluminim Beadlocks
Hi, does anybody know if Losi makes beadlock rings for their aluminum rims in a color other than black? I was going to switch out the red ones on my stock rims but they have less attach holes. Thank you.
stomper4x4.com is offline   Reply With Quote
Old 05-20-2009, 09:34 AM   #2
I dont think so. You can buy just the plastic rings for you stock rims in either red, blue, or black.
For even more options you can sand down the color on them and dye them whatever color you want. Or you could leave the stock color on them and dye over that.
soundcolor is offline   Reply With Quote
Old 05-20-2009, 09:43 AM   #3
He's ref to the alloy ones. They only have the stock black rings. You can paint them though, some light sanding is all you would really need. They will get scratched up either way so there isn't much point to take tons of prep time. Scuff them, rattle-can them and remount.
mOOsE is offline   Reply With Quote
Old 05-20-2009, 10:30 AM   #4
Losi Rep
Rich Trujillo's Avatar
Mick,
Our beadlock rings only come in black and the stock MRC molded rings have a different bolt pattern. I have not tried it myself, but if seen easy off used to remove anodizing. You could then have them polished or even re-anodized if you have an anodizer in your area.
Rich
Rich Trujillo is offline   Reply With Quote
Old 05-23-2009, 01:33 AM   #5
I would suggest the Mayhem 1.9 cdp's. They work great and look nice also. never thrown a bead at all.
CRAZYACE63 is offline   Reply With Quote
