06-01-2009, 05:25 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
| Spring softening
Does anyone have any clue how to make a spring softer. I am waiting for some much softer springs to come in, but in the mean time all I have is some stupidly hard springs. I tried heating some other smaller springs I had laying around and was able to make them really, really soft. But the harder springs I have dont seem care how hot I get em, and for how long. (I left one under the torch for 25mins it was absolutely glowing red). Any ideas? |
06-01-2009, 07:10 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
I was going to say try heat but you got that coved already. I dont know man you got me.
Last edited by wheelhead4x4; 06-01-2009 at 07:11 PM. Reason: needed space in wording |
06-01-2009, 07:15 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
if its anything like metallurgy, to soften something you must heat it to extreme heat like you did but instead of letting it cool off all of a sudden it needs to slowly cool down. when i'm drawing back something hard at work. I usually place the oven on 1850 (depending on the material) once it gets up temp, I cut off the oven and let the metal cool down slowly with the oven. normally takes until the next day or late that night. I doubt you have anything like that laying around the house though.
06-01-2009, 07:49 PM | #4 |
I dont have that kind of a oven, but I do have an aceteline torch. I'll give it another shot tommorow. I didnt really let it cool down slowly, just dunked it straight into some water.
06-01-2009, 10:07 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
maybe its a dumb newb question but wouldnt thinner shock oil soften the shock with less compression pressure? In my 1:1 air shocks less nitrogen psi makes the set-up softer so sub the nitrogen gas for the shock oil and same principle...
06-02-2009, 12:38 PM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
you can try burying it in dry sand for the cool down. this will help hold the heat in for the cool down. Dry the sand on a baking sheet in the oven at 150deg or so if it seems wet.
08-09-2009, 10:48 PM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Well maby but you would lose some damping action of the shock. it would be a bit bouncy and would not compress as well as with a properly set up shock and spring.
