06-02-2009, 08:54 PM | #1 |
Newbie Join Date: May 2009 Location: piedmont
| servo saver ??
either i didn't have it screwed in tight enough and it blasted out like a rocket when i turned or it jumped out and ran away when my rig fell over backwards, either way its gone. Im talkin about the screw and spring. Im pretty sure that i dont want to run without the spring, i think it will burn up the servo. i have noticed in some pics that there are alternatives what do you guys recommend i replace this with thanks |
06-02-2009, 08:59 PM | #2 |
Quarry Creeper Join Date: Oct 2007 Location: PF, WI
Ditch the stock servo and get a better one and use a solid servo horn |
06-03-2009, 08:40 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
If you dont have the cash to replace the servo (hitech 645's go for around 30 bucks) and you need to keep the stock servo as long as you can, just take the servo saver arm to your local hardware store and pic out a spring that fits, also get a screw. You may want to take the whole servo with you just to be sure you get what you want.
