06-03-2009, 12:05 PM | #1 |
Newbie Join Date: Jun 2009 Location: u.s.a.
| Help! My u-joints are cursed!
I recently bought a Losi mini rock crawler to see if I liked the hobby. I LOVE crawling, but I keep having the same problem with my u-joints. They keep breaking. I broke one, bought more stock ones, broke two replacement stock, and one more original stock. So I upgraded to some hop up u-joints, and broke three new upgraded joints in one night. My car is cursed. This seems like it has to be a problem with my car, I'm not driving it hard, and every u-joint out there cant be bad...right? thanks for your help, rkcrwlr |
06-03-2009, 12:25 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Phoenix
This is fairly common when using an upgraded motor. The extra torque can be a bit much for the stock driveshafts. It's less common with the stock motor. If you're using the stock motor, this is a sign that you're a bit heavy with the throttle. Back off a bit when it's bound up, it's either gonna break loose or break something. There are a few solutions for strengthening the driveshafts. 1. Use female shafts on both ends. Join them in the middle with the male spliney bit. You'll have to shorten the female ends, but keep them as long as possible to minimize the exposed amount of the spliney bit. I ran this for a while after I got my HH motor, and it worked well. There is a thread on here somewhere with pics. 2. Buy MIP driveshafts. They are machined out of steel, with hex slidey-bits. They are _extremely_ strong, and work better at extreme pinion angles. I have these now, and they rock! I'll break something in the transmission or axles before these break. There are other solutions out there, but these are the 2 I know about. HTH, Rich C. |
06-03-2009, 12:28 PM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Sierra Foothills
| RC4WD Punisher Shafts
I just got a set of the RC4WD Punisher Shafts as they call them. Looks like they are probably indestructable. I ordered them right off the rc4wd.com website and got them in two days.
06-03-2009, 12:46 PM | #4 | |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
06-04-2009, 08:13 AM | #5 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Thats what the slipper is for. Use it, its free.
06-04-2009, 11:37 AM | #6 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
I doubt you are breaking the U-joints themselves. Your most likely breaking the driveshafts. If thats the case and when you broke your stock ones and replaced them with either the Integy, or HotRacing shafts then thats a huge problem right there as they make some pretty crappy shafts. The new punisher shafts should hold up to all the abuse you can throw at them. You may also want to seriously consider adjusting that slipper clutch. Much better to wear out a clutch or gear face than to replace motors, gears, shafts and lockers.
06-04-2009, 04:53 PM | #7 |
Rock Crawler Join Date: Oct 2008 Location: Florida
One of the other members posted these joints http://www3.towerhobbies.com/cgi-bin...&I=LXGBH2&P=SM Use them with traxxas shafts and they work great! I used them on my mrc scaler to extend the rear wheelbase. Here is the link from the member I got the idea from. Pede Shaft Conversion (w/ PICS) Hope this helps |
06-06-2009, 01:59 PM | #8 |
| thanks
Thanks for all your help, Ive since replaced the losi mini with a axial ax10 and love the bigger size. the guys at the hobby store said it was just bad luck that I broke 7 u joints, I think my slipper was defective, since I never saw it actually slip. anyway, love working on the new crawler, and will probably post some pics of my homemade mods.
06-06-2009, 04:33 PM | #9 |
06-09-2009, 12:24 AM | #10 | |
Newbie Join Date: Apr 2009 Location: Los Angeles
06-09-2009, 06:38 AM | #11 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
Is teshaft breaking or the Joint? My new rig I just built had a set of faulty joints.They were not breaking but the pin that holds the joints together fell out of every Joint. |
06-09-2009, 08:01 AM | #12 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I use Traxxas Stampede shafts....never gonna break. Use these for the pinion and trans: http://www3.towerhobbies.com/cgi-bin...?&I=LXGBH2&P=7 You will need to clearance the motor plate some and the trans just a touch. |
06-12-2009, 04:43 AM | #13 |
Quarry Creeper Join Date: Feb 2007 Location: waterford
MIP does make Center drive shafts for the MRC. They are sweet! |
06-12-2009, 09:21 PM | #14 |
RCC Addict Join Date: Jul 2006 Location: barstow
you can go right to mips website and get them
