06-04-2009, 12:52 AM | #1 |
RCC Addict Join Date: Jun 2008 Location: Fresno
| my 4ws tuber mrc build *time lapse video !
thought id just post my current mini crawler build. before you even point out the obvious, yes i know 4ws is not legal in competion. this build is purely for fun, and to see how far i can take this mini. i have my 2.2 to comp w/ and a super class rig im begining to save up for. list of mods and upgrades: dmg snipe v1 tube chassis losi aluminum shocks tcs internal springs losi cf servo/battery plate X2 losi lipo battery motoworx billet aluminum ufo wheels w/ rings (via JFab) losi mini slider motor losi front rear and center metal diff lockers 4ws mod tekin fxr dynamite aluminum servo arms custom made heavy duty steering links rpm universal servo mounts deans connectors for all electrical connections rocksmith gear jelly losi rock bashers Link to time lapse build video ------->>> http://www.youtube.com/watch?v=iO62-epYjso now for more pics ^^ can this steering link geometry get any better? i vote that it cannot! more upgrades soon went to my lhs today and picked up 2 hs-5245 mini servos, and a set of g8 flat irons. i'm also begining talk to some builders about a campbell style buggy Last edited by NeXt559; 06-04-2009 at 08:27 PM. |
06-04-2009, 11:36 AM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
IF you get a Campbell Chassis, I got dibbs on your old one!
06-04-2009, 05:14 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
Nice vid/build!!! P.S. Aesop is the sh!t |
06-04-2009, 09:41 PM | #4 |
Rock Stacker Join Date: Mar 2009 Location: SC
i used to run 4ws on mine but took it off, it was fun for a while but i have alot more fun with front steer. cool build tho
06-04-2009, 11:41 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Canon City
I have my personal campbell mrc chassis if your interested. VERY lightly used. Let me know! |
06-05-2009, 08:58 AM | #6 | ||
| i'll keep ur user name in mind when the new tuber is delivered thanks, and you wont get any arguments there. i actually met aesop when i went to NY last year, he was helping w/ pomoting a show but didnt persform himself. a really intelligent and genuine guy imo Quote:
the mini slider really makes this thing haul btw ne one know if the stump puller motor is stronger than the losi mini slider? Quote:
thanks for helpin out w/ the wheels btw | ||
06-05-2009, 05:15 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
06-05-2009, 08:33 PM | #8 |
06-06-2009, 06:40 AM | #9 |
Rock Stacker Join Date: Mar 2009 Location: Angeles City, Philippines
which one burned up? - the hs-5245?!? I am about to buy one of those to replace my stock losi servo...
06-06-2009, 09:58 AM | #10 | |
when setting up your steering rate make sure to check it both left and right. adjust the steer rate to whichever side has the least throw. adjust the steer rate only as far as the servo will go w/o buzzing. then pull back again just a tad. this is steering servo 101 guys before i upgraded to the hs5245's i was using the stock losi mini servos. and ive had my mrc since it's release. the only reason ive had to ugrade was because of how much heavier the rig is compared to its stock form. and a hard turn w/ all that extra weight has caused gear stripping in my front servo. to be honest the rear stock servo is still in perfect shape also ive been getting numerous pm's about what parts will be needed for the 4ws mod. note that all parts i list are the stock losi parts and can be updraded to your choosing Axle Shafts: LOSB1406 Axles: LOSB1407 Front Spindles & Carriers with Hardware: LOSB1409 Steering Links, Long & Shord: LOSB1410 Complete Screw Kit: LOSB1419 *not really a "must have" you are only going to need the one long screw for that connects the knuckle, drang link and tie rod. but it is good to have in tool box in case you loose any tiny screws. Servo Plates & Mounts: LOSB1421 Servo Saver & Arm Set: LOSB1422 *you'll mainly need this if are using the stock losi mini servo. MSX12 Digital Mini Servo: LOSB0822 *other mini servos that are drop in replacements would be the Hitec HS-225MG; HS-225BB; HS-5245MG (if they are any i missed please pm me and i will edit if needed) as for wiring you either need an extra 3rd channel on your radio w/ at least 3 positions or a wire harness w/ a reversing module Last edited by NeXt559; 06-06-2009 at 10:01 AM. | |
06-11-2009, 04:00 PM | #11 |
How are u suppose to adjust the servo? Had it set to turn till each knuckle was just a c-hair away from each steering stop. No dice. Put a 645 on and no probs... Plus even after you Buy the full size servo mount they are still half as much as the 5245's. Make yer own mount and save even more. More torque and no issues.
06-11-2009, 07:39 PM | #12 | |
Rock Crawler Join Date: Nov 2008 Location: CO
06-11-2009, 09:48 PM | #13 | |
| teaser for the new tuber Quote:
dont know what radio you're using but imo the stock radio doesnt have the adjustability required to use your servo at its optimum level (btw im using a dx3r) example: my subtrim is set to "L3" left steer rate is set at 93% right steer rate is set at 81% even w/ the different steer rates i get the equal amount of turn left or right. also i stuck w/ the mini size servos for 2 reasons 1- imo the standard size is looks way to big on the mrc axles 2- i havent needed all that extra torque...... yet i say "yet" because the new tube chassis is being designed and fab'd by gadge as i type ive always admired this rig built by a local 1:1 shop after sending gadge some reference pics he sent my a quick doodle a very short few hours later here's a quick lil teaser for the build as you might notice it's noticable larger that orignal. we're shooting for maybe 1/14- 1/12 scale i asked him to make the roof lne a tad lower that the top of the head rest. i just thought it would help bring the gc down a lil and i also thought it would give the overall rig a stout, and more agressive look Last edited by NeXt559; 06-11-2009 at 09:59 PM. | |
06-12-2009, 03:46 AM | #14 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
Well after searching thru alot of pictures, think I got a plan....and then some " The NeXt Trail Gear MiNi " and yes we are building a 1/12 scale rig with the changes as requested by Next and a few to make things fit n clear, ...gotta nip/tuck panhard mounts a bit And to top off the doodle decided to build one for myself, or someone..?? Well call it a styling exercise, ...practice or ???? "Now heres where (love this part) I make Next say "awesome" again...... ###keep in mind this is going to be a bit larger to fit AX-10 but a shape of things to come, I'll do a 2.2 or AX thread when I have time The chassis for NeXt will be 75% of this size for 9.5" wheelbase Sorry for the tease NeXt but .........got it in my head THE SHAPE THE TUBES AND DONT FORGET DETAILS |
06-12-2009, 01:08 PM | #15 |
runnin to the LHS to pick up chassis plates for template now I can start |
06-12-2009, 03:07 PM | #16 |
Will I/the rest of us be able to get this tube chassis? I imagine so, but I just want to be sure. It looks awesome, and it's just a 'doodle'.
06-12-2009, 03:52 PM | #17 |
Yep and all you gotta do is ask ...."I knew someone woulde use awesome...... able to fit mini...1/12th scale AX-10 or any rc4wd in 1/10th scale and w/k in just under 1/8 |
06-12-2009, 06:27 PM | #18 |
aww .... amorton94 beat me to it but im gonna say it neways looking awsome gadge my paypal tab is ready and waiting for you to tell me when to pony up the funds |
06-13-2009, 02:34 AM | #19 |
got the stock chassis plates to use for template seeing that I'm just stretching the chassis 1" so stock links will work..just have to extend d/s's well heres the start of the MiNi chassis for the small scale 1/8 round stock...with p-coat = 1 5/8" to scale well gotta run n fire up the torch....... |
