06-04-2009, 02:00 PM | #1 |
Newbie Join Date: Feb 2009 Location: portland
| Motor getting hot
I've noticed that my Holmes tmm is getting very hot. I noticed it when i put my finger on the pinion gear. I've run the same set up before and it never got anywhere near this hot. The slipper clutch doesn't seem to slip as easy as other ones i have had but the stock motor didn't have any problem with heat. I'm running Flat irons or blue crushers and there is no discernable difference. What should I be looking for? Thanks MikeV |
06-04-2009, 02:14 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
same here. mine gets too hot to touch. drivetrain seems to spin freely. running a 14t pinion on 2s with a sidewinder micro.
06-04-2009, 02:28 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
how much weight you runnin in your wheels |
06-04-2009, 03:38 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Are you sure your gear mesh is set correctly and is your slipper set to tight? |
06-05-2009, 08:17 AM | #5 |
06-05-2009, 08:19 AM | #6 |
06-05-2009, 05:59 PM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
first off the slipper clutch in these things suck! but it sounds like your hear mesh is off. The motor will get warm, especially if you are just driving it around as fast as you can go rather than just crawling. When I installed the slider motor that thing ran way too hot, and I tried many different pionion sizes. My hh tm gets pretty hot after running a full pack through it bu nothing too bad.
