06-04-2009, 09:17 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Desert
| Help mrc
Help my wheels wobbly when I full throttle. What happens |
06-04-2009, 09:43 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: SoCal
Your wheels are likely not very balanced. You can put silly putty, or some type of sticky weight to part of your rims to balance them out.
06-05-2009, 02:36 AM | #3 |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
All my crawlers do that. I imagine it would be difficult to balance them with all the lead in the wheels. Besides, on crawler speeds it does not matter if the wheels are out of balance. Unless offcourse if you do a lot of speedcrawling... |
06-05-2009, 11:15 AM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
I highly doubt this is the case, but it could also be due to a bent stub shaft. All crawlers wheels wobble, that's just a fact of the sport. |
06-05-2009, 01:59 PM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
giant tires, and lots of foam equals wheels that wobble.
06-05-2009, 05:56 PM | #6 |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
Yeah I have blasted through stuffing my foam in and had a bad wheel wobble, and then took my time "massaging" the foam into the wheel and still had a wobble. The bottom line is you are not going to be using a crawler at high speeds so it does not really matter.
