06-08-2009, 09:22 AM | #1 |
Newbie Join Date: May 2009 Location: SoCal
| Dark Soul OMF Wheels
Newbie here, I just got a set of the OMF's from dark soul, wanted to know how you guys are venting cause I dont want to drill the wheel maybve just thruogh the tire itself??? Thanks
06-08-2009, 09:34 AM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
I used a leather punch and put an 1/8 inch hole in the tires. DarkSoul also recommends that you can drill holes in the plastic rings and that will allow air to pass through.
06-08-2009, 09:40 AM | #3 |
I used the hot tip of my soldering iron to make a couple holes in each tire. Cut and seals it off at the same time.
06-08-2009, 10:13 AM | #4 |
Thanks guys, im guessing punch the holes dead center of ot tread?
06-08-2009, 10:32 AM | #5 |
It all depends on what tires you have. I have the Bashers and they have tread that allowed me to punch a hole inside a raised tread portion so its not in an area that would be ripped possibly.
06-08-2009, 10:44 AM | #6 |
Ok thanks, im trying out some flatiron so i'll go between the lugs in the center
06-08-2009, 04:24 PM | #7 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Any reason in particular you don't want to drill through the ring? It's plastic. Piece of cake. Not hard to do, no damage to the look of the wheel. Then you don't have to do all your tires if you change down the road. |
06-09-2009, 08:46 AM | #8 | |
Rock Stacker Join Date: Dec 2008 Location: Richmond Hill,GA
I would like to see a pic of where you drilled it.I also have the OMF wheels and Flatirons.BTW,not to hijack,but do any of you use foam inserts or just tirewith no insert? | |
