06-10-2009, 04:14 PM | #1 |
Rock Stacker Join Date: May 2009 Location: grand junction
| my mini
hi all. this is my first post i have been working on this truck for a bit. let me what you think.. so as you can see i put a bigger servo on it(hytec hs-5625mg). rip out the battery tray moved the shocks to the frame. fliped the tranny and moved the battery. it runns really good i just dont know what to do with it now. |
06-10-2009, 05:25 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
Way to much articulation, limit your shocks
06-10-2009, 09:23 PM | #3 |
is to much articulation bad ? sorry im still new at all of this.
06-10-2009, 09:57 PM | #4 |
06-10-2009, 11:16 PM | #5 |
Pebble Pounder Join Date: Dec 2007 Location: Tucson, AZ
mmmmm lots of torque twist
06-10-2009, 11:32 PM | #6 | |
Rock Stacker Join Date: Mar 2009 Location: SGV, LA, CA, US
Good info... but WHAT HAPPENS when you have too much articulation? Anyone? Thanks | |
06-11-2009, 12:01 AM | #7 |
Rock Stacker Join Date: Oct 2008 Location: Wilsonville OR
I would recommend some cross bracing to keep the chassis from flexing under load and add some tubing about 3/16" under the pistons in the shocks to lower your rig and outside on the shaft about 3/8" to limit articulation, this will help a little with torque twist.
06-11-2009, 03:57 PM | #8 |
Rock Crawler Join Date: Apr 2006 Location: Thorp WA, more sheep than men...
| Tire will follow all the way up an obstacle until you drive right upside down. Sucks. Learned the hard way cause I build 1.1's and more flex is better but not on RC's... Hope that answers yer questions...
06-11-2009, 09:01 PM | #9 |
cool thank you for the input. any other thing i might want to do ????
06-12-2009, 07:35 AM | #10 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
first, reduce the articulation alot. Brace up those TVPs. Build, or buy at least a rear 4 link. Get some metal lockers if you haven't already, some true beadlocks (or you can do the beadlock conversion on your stockers) and some better tires. What else you do from there is totally up to you. You can search around here, and follow some of the build threads to see the mods that others are doing. You can take it as far as you want!! Good luck Darryl |
