06-20-2009, 03:22 PM | #1 |
Newbie Join Date: Mar 2009 Location: Humboldt County
| Fej's Fubar Mini Skeeter
Bought my mrc on the ebay back in march. It was slightly used & still stock, but it came with a set of losi aluminum shocks and the peak charger. Picture from the ebay listing. First thing I did was install the aluminum shocks. Then took it crawling. Got droop springs and 3 link plates from TCS. The droop made a huge difference. Shortly after that my crawler took a nasty fall, and I ended up bending the chassis next to one of the shock mounts. I used that as an excuse to get a new one, so I ordered a mini skeeter chassis from MTHead. I started putting it together. I had to grind off some plastic from the bottom of the transmission case so it would mount flush to the skid plate (EDIT: John has addressed this problem, and the current versions of the chassis have a notch machined into the skidplate that allows the tranny to mount flush). Also I had to grind a little off the 3 link arms so they would clear the chassis. Sat like this for a few months. I picked up some bent links and proline 1.9 titus beadlocks at my lhs. I installed the bent links in the rear, but they limited the articulation to much so i took them off. Can't wait to get these wheels installed. I ordered delrin tubing from rcbros to make upper links. I also got front & rear metal lockers from TCS. And got started getting it running yesterday and finished this morning. I'm still using the stock wheels & tires until my 1.9 chisels get here. Rear four link. I'm going to move the rear shocks outboard & four link the front when I get some more screws and whatnot. Ground clearance at the skid is a hair under 1.75". Ready to go. Gonna take it out after work today and see how it does, I'll try and get some pictures while I'm out there. Last edited by Fej; 06-23-2009 at 12:13 PM. |
06-20-2009, 06:22 PM | #2 |
Newbie Join Date: Nov 2008 Location: Bradenton
Looks awesome! Good work Fej!!
06-21-2009, 11:57 AM | #3 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
I bet if you move the front shocks to the outside of the Chassis you can squeeze that factory battery on the 3 link Nice job! I dig the skeeter |
06-22-2009, 03:04 PM | #4 | |
| Thanks! Quote:
Took it crawling for a little yesterday, not sure how I feel about the ride height. Probably just need to get used to it, I'm hoping the new tires & wheels will make a difference... Got my 1.9 Chisels and hardware upgrade kit! Got one of the tires mounted for now, couldn't help myself. They are VERY firm when mounted on the Titus wheels with the weight rings, they're fine with out the weight. I'm gonna start with no weight in the back and use the weights up front. From what I've read enlarging the inner diameter of the foams will fix the firmness problem. Mods to date: Fubar Mini Skeeter Chassis Rear Four Link Losi Aluminum Shocks Losi Metal Lockers F&R Proline 1.9 Titus Beadlocks Proline 1.9 Chisel Tires TCS Hardware Upgrade Kit TCS Soft Droop Springs I'll post more after I get the other three mounted. The weather is far to nice to sit inside and mount tires. Last edited by Fej; 06-22-2009 at 08:15 PM. | |
06-23-2009, 02:49 AM | #5 |
Got the the tires, wheels and hardware upgrade installed tonight! Button head screws for the underside of the axles and lower link mounts. I love the wheels & tires on this thing!!! Gonna try and take it crawling tomorrow. Can't wait to try the new tires, they're sooooo much stickier and softer! Last edited by Fej; 06-23-2009 at 03:30 AM. |
06-24-2009, 12:37 AM | #6 |
Finally took it crawling today, went out to a place called Elk Head with my buddy Dean to take pictures and play with the crawler. The chisels are fantastic, so much more traction than the stockers... Pictures (some are mine and some are Dean's) Caught it right as it started coming off the rock Last edited by Fej; 06-24-2009 at 03:40 AM. |
06-24-2009, 01:06 AM | #7 |
Quarry Creeper Join Date: Apr 2006 Location: SO CAL
The mini is looking great Jeff. Dang, I need to make a road trip out to that place. It looks sick, and perfect for 1.9, or anything crawler related at that.
06-24-2009, 02:23 AM | #8 |
Rock Stacker Join Date: Oct 2008 Location: wellington
your mrc does look great! that wheel and tire combo look sick! thanks peace
06-24-2009, 03:28 AM | #9 |
I'll trade ya crawlin spots |
06-24-2009, 02:15 PM | #10 | ||
Looks like I'm going to be needing a new servo soon, the stock one started make all sorts of nasty noises after crawling yesterday. Guess I got it bound up a few times to many Quote:
I think I'll hang on to this spot | ||
02-07-2011, 12:45 AM | #11 |
Been awhile since I've updated. Added HR wide hexes and a new body since the last post. Started working on a BTA steering setup tonight. Got a prototype mocked up with a piece of coat hanger. Clearance is the same at full lock Not sure what I'll make the final arm out of but it looks like this design might work. Was a lot easier to figure out than I though. Ordered a couple fun things the other day, should be some significant changes happening soon... Last edited by Fej; 02-07-2011 at 02:16 AM. |
02-07-2011, 07:32 AM | #12 |
Rock Crawler Join Date: May 2009 Location: 354
nice work, not sure if the coat hanger will hold though.
02-07-2011, 09:32 AM | #13 |
02-07-2011, 10:10 AM | #14 |
Rock Stacker Join Date: Jul 2004 Location: hell
sweet truck
