06-20-2009, 09:40 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Desert
| How to get a droop setup
I was wondering what I need to get a droop shock setup. Also how do I install it after I get it? |
06-21-2009, 12:21 AM | #2 |
Newbie Join Date: Dec 2007 Location: Charlotte
Droop suspension works the opposite of a spung suspension. Instead of the shocks being fully extended and then compressing for travel, they are setup so that they are fully compressed and then extent for travel. There is also the semi-droop which allows for a bit of both. To run droop you must do the following: 1. Remove the outer springs. 2. Insert springs (I used pen springs) on the shock shaft (inside the shock cartridge). If you search on the forums you will find more information. Good luck. |
06-22-2009, 12:42 PM | #3 |
Rock Crawler Join Date: Oct 2008 Location: Florida
These are axial shocks but same concept. remove outer spring, replace with small inner springs like said above pen springs or from hardware store, re-fill with desired fluid. Hope this helps |
06-22-2009, 12:46 PM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
The best springs for the MRC are off the Losi Micro-T
