06-25-2009, 01:42 AM | #1 |
RCC Addict Join Date: Mar 2009 Location: Chilton
| Losi MRC receiver Problems
I have had this losi going for about 2 weeks now and my receiver went out or at least it seems like it. I called Losi and they sent me a new one and it does the same thing. I put the bind plug in and the green light flashes real fast when I turn it on and then I turn on the controller and it goes out for a minute then comes back blinking really fast again. After that I remove the bind plug and turn everything off and then back on but the rx does nothing. I have tried it straight off the esc off of a bec and off of a receiver pack and still the same thing with all of it on both receivers. Does anybody have a clue? Do I have 2 bad brand new receivers or am I just over looking something? I can hook the one up off my super and it works on it with my super controller. I also borrowed the receiver from a friend off his mrc and it worked fine but I tried it with his controller instead of trying to bind it to mine.:?
06-25-2009, 03:42 AM | #2 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Did you put new battery's in your controller?
06-25-2009, 07:32 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
sure, always point out the obvious... no seriously, new batteries in the radio cures 99.9% of all reciever problems |
06-25-2009, 10:33 AM | #4 |
Yes I put new batteries in the controller. It still did not help. But the strangest thing happened a few minutes ago I was going to mess with it a little more and turned it on and it worked fine. Hopefully it will stay that way I haven't tested the other receiver yet and I am not sure I want to try it. My luck I will try it and neither one of them will work again. |
06-25-2009, 05:31 PM | #5 | |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
what brand were the new double A's that you used? Your best bet is to get a good name brand rechargable. Once my factory sent batteries went down I went to Energizers and they lasted all of about 5 minutes so I found some LiPo's in Double A and Triple A (triple A's for my Xmod), not had a problem since! | |
06-25-2009, 07:00 PM | #6 | |
06-26-2009, 12:16 AM | #7 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
I'm using the Duracells in all of my controllers and haven't had a problem with them in my Losi Radio as of yet.
06-26-2009, 06:33 PM | #8 |
duracells... theres your problem... Get a set of sanyo 2700 NiMh and never look back. Bar none, the best AA battery ever. |
02-09-2010, 06:05 AM | #9 |
Newbie Join Date: Jun 2009 Location: UK
would some 2450mAh energizer rechargables be up for the job? they are the best one that my local eletronics shop sell.
02-09-2010, 08:26 AM | #10 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
02-09-2010, 08:47 AM | #11 |
02-10-2010, 03:04 AM | #12 |
Newbie Join Date: Jan 2010 Location: Omaha
I had this same problem. Binding was very erratic. I went to my LHS and they swapped out the Tx and everything has been fine since. I guess it is possible that you got to bad ones in a row, but it sounds like everything is working out.
02-10-2010, 08:30 AM | #13 |
Pebble Pounder Join Date: Jan 2010 Location: Gluing my mirrors back on!
You guys DO realize that transmitters actually work better with alkaline batteries than rechargables? Alkalines put out higher voltage per cell. I have used both rechargables and alkalines in my radios and the rechargables drop to too low of a voltage before Energizers or Duracells every time. (1.5v/cell > 1.2v/cell.) I have an extremely hard time believing anyone got only 5 minutes from a set of Energizers. :?
02-10-2010, 04:59 PM | #14 |
Newbie Join Date: Feb 2010 Location: Oregon city
well from my experience as soon as you buy the car tear out all the losi electronics and get all new stuff. I went through 2 recievers, 1 servo, and an ecm. My friend went through 1 reciever and 1 servo, and my wifes car went through 1 reciever. I lost my first reciever,ecm,and servo befor it left the house. We got all new (non losi) stuff and all is good. Dont think Im down on the car at all, I love mine and have ad tons of fun with it, I just think they come with poor quality electronics.
02-10-2010, 05:10 PM | #15 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
never hard of 2 bad rec . wonder if it the radio
02-11-2010, 01:39 AM | #16 |
Tried the radio on 2 other cars and it was fine, I went through the whole car top to bottom looking for another issue but it was the reciever. Ive had the new reciever for a while now and have had no problems and am really enjoying the car.
02-21-2010, 05:04 PM | #17 |
Rock Stacker Join Date: Mar 2009 Location: SGV, LA, CA, US
| welcome to the MRC problem club. Did you ever figure your issue out? I replaced my ESC still bad maybe I should replace the RX :-/
02-21-2010, 05:40 PM | #18 | |
Pebble Pounder Join Date: Dec 2009 Location: North Wales
Sorry to hijack for a second but... Quote:
Err. Sure the starting voltage on a rechargeble is lower and most manafacturers take this into account when building handsets. But as for longer life of non rechargeable when used? The graph on the link speaks for itself and shows it takes a lot longer for the rechargeble NIMH to drop to 1v, take a look here http://www.greenbatteries.com/batterymyths.html As for your RX problem, if you have got good charged batteries in their and have done the rebinding process and its still playing up then its time to check battery connections, replace the losi ones with some deans and also check the antenna wire isnt damaged inside the rx casing, not heard of it happening but its a possible cause. | |
