06-29-2009, 06:03 PM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
| missing D-shaft pin...
So I was wheeling earlier today and the rear axle stopped pulling. Upon further investigation, it seems that I lost a pin in the universal joint. my question is: what is a good substitute that I can use to replace it till I cn get a new d-shaft assy?
06-29-2009, 06:08 PM | #2 |
Hateraide Join Date: Dec 2008 Location: Mission BC
you could cut the end of a drill bit |
06-29-2009, 06:28 PM | #3 |
06-29-2009, 06:30 PM | #4 |
im not possitive
06-29-2009, 06:35 PM | #5 |
AH HA! I fixed it with a small nail that I cut down to size and then squeezed it with a pair of pliers to crimp the cut end like a rivit! Thanks for the drill bit insperation Code!
06-30-2009, 08:55 PM | #6 |
Rock Stacker Join Date: Jun 2009 Location: im in iraq
if you add a pice of shrink rap around the joint it helps keep the pins in
06-30-2009, 08:58 PM | #7 |
06-30-2009, 11:43 PM | #8 |
Newbie Join Date: Mar 2009 Location: Anacortes
07-01-2009, 05:44 AM | #9 |
im not positive but i think i used 3/8 the best thing to do is take your drive shaft off and go to radio shack and find the size that fits. you will need to take the small set screw out its eases to take the axel side off. you can pm me and ill send you some pics
07-01-2009, 09:19 AM | #10 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
i found that traxxas body pins fit snugly in the pin holes as well. just pinch the ends so they don't fall out again
07-01-2009, 11:50 PM | #11 |
| haha sweet i went to home depot earlier today (before reading this) and picked up 3/8" cause it looked like the right size. should hold me out until i get MIP shafts thanks jrba
