07-14-2009, 01:47 PM | #1 |
I joined the Band! Join Date: Jul 2009 Location: why do you care?
| Chassis help
Will I be able to fit a tamiya jeep wrangler body on the losi mini crawler with the tcs l-trail chassis if the wheel base is extended all the way(10.5 inches)? Will I need to get new drive shafts to fit the wheel base or will the stock ones work?
07-14-2009, 04:35 PM | #2 |
RCC Addict Join Date: Jun 2009 Location: California
Sounds like an experiment you will have to try and let everyone know what ya did. I dunno if I would turn the MRC into a scale rig. I started with an Axial to make my scaler. the MRC is considered a mini and its a 1/18 as were the Axial is a 1/10. Just buy the Bronco Body style for the MRC and slam it. Looks very cool! |
07-14-2009, 11:00 PM | #3 |
what is the body called?
07-15-2009, 12:16 AM | #4 |
This is the link. Losi sells it. there are also other body's for the Mini that look cool, just not the Bronko http://www.losi.com/Products/Feature...rodId=LOSB1313 |
07-15-2009, 11:59 AM | #5 |
The mini work good as a 1.9 scaler. The stock Tamiya Wrangler body will work. You will just have to find a way to mount the body. The axles should be a good fit for that body. I don't remember to exact track witdh for the CC01 but I have test fitted a New Bright FJ Cruiser body (that fits the track width of the CC01 perfect) on the MRC Axles and it was spot on.
07-15-2009, 01:57 PM | #6 |
Pebble Pounder Join Date: Feb 2009 Location: Wisconsin
the mrc makes a good scale rig, but you would need to extend your drive lines.
07-15-2009, 02:31 PM | #7 |
ahh I didn't see in your post you already got tcs chassis for it, should be cool looking. I got the tcs for the axial. looked nice with the landcruiser hard body on it.
