07-16-2009, 12:50 AM | #1 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
| is there a trick to getting the yokes off?
I'm having lots of trouble disassembling many parts of this losi due to the hex heads being so small and them being installed so tight. I'm specifically trying to get the yokes off the axles and transmission. The hex is starting to strip the set screw. Is there an easier way to remove these? |
07-16-2009, 06:00 AM | #2 |
Rock Stacker Join Date: Feb 2009 Location: Phelan
When I tried getting mine out, they did the same thing. I took a dermal to it a ground out the set screw, I was putting in the mip cvd's so I didn't care.
07-16-2009, 07:39 AM | #3 |
Pebble Pounder Join Date: Feb 2006 Location: Evanston
Take a soldering iron get iron hot first.Stick point on setscrew for 10 seconds..will turn out verry easy |
07-16-2009, 03:48 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
1/16 allen wrench when the 1.5 rounds out the 1/16 fits pretty tight i ruined 2 1.5's then used a snap on 1/16
07-16-2009, 04:20 PM | #5 |
the 1/16 is rounding it too. defiinitely grips the hex better but wont turn the f'ing set screw. tried soldering iron heat to no avail.
07-16-2009, 05:12 PM | #6 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
Hmm. If nothing, you could cut the damn things off as mentioned above, or you could also try a dab of your favorite metal adhesive/epoxy and glue the tool to the screw. If you do, don't use too much! EDIT: perhaps you could drill it out if you have a smaller size drill but; or, use a small bit to make a smaller hole for an Allen to fit snuggly. |
07-16-2009, 06:22 PM | #7 |
RCC Addict Join Date: Jun 2008 Location: Fresno
have u tried wd40 or a really light silicone oil? (the kind used for airsoft maintainence)
07-16-2009, 07:03 PM | #8 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
I vote drill it out, and tap it to a 2mm
07-17-2009, 08:18 AM | #9 |
Newbie Join Date: Feb 2009 Location: portland
I used a lighter. MikeV |
07-17-2009, 07:21 PM | #10 |
Rock Crawler Join Date: Jun 2008 Location: Naples
Sounds like they put them in with strong loctite, heat is the best way to loosen loctite. The soldering iron idea works, but if trying once fails, heat some more.
07-17-2009, 07:58 PM | #11 |
Newbie Join Date: May 2009 Location: Matewan
Swearing usually helps me. On a serious note though only thing I could think of is heating it up. |
