07-17-2009, 11:22 AM | #1 |
RCC Addict Join Date: Jun 2009 Location: California
| full size servo with lipo on front axle
Has anyone fit a full size servo with the losi 600 mah lopo next to it on the front axle. I have seen it with the mini sevo. Just wondering if I should buy a mini servo again because that is the setup I would like to run. Thanks. |
07-17-2009, 01:00 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
Im running a hitec 645 with a mystery 900 lipo. The battery doesnt lay flat it leans up against the servo. I couldnt get a mini servo to last very long for me. I kept smoking them.
07-17-2009, 02:30 PM | #3 |
Interesting. Didnt think they would burn up that quick. The first thing I did was put a full size servo on the mini. So you dont think the HS-225 would do the job. Have to rethink my placment of stuff. Thanks!
07-17-2009, 02:50 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Get a 645, stay away from the 225, it will give out. I run a hs645 with 2s1300 on top of the servo, works great.
07-17-2009, 03:13 PM | #5 |
Only problem is I run my rig slamed to the ground. And the Body is slamed on top of the DNA frame. I dont have enough room to run anything on top of the servo. The servo already hits the body. Will have to rethink something here. :?
07-17-2009, 03:14 PM | #6 | |
Ya the 225's just cant cut it. I even tried a 5245 and burned that up. A couple guys on here are even using a futaba s9551 that has 98oz of tourqe. This servo has a low profile and give you a little more room up there. BTW the 645 has 133oz of tourqe. | |
07-17-2009, 03:37 PM | #7 |
Yes im running the 645, its a big servo, runs good and stays very cool.
07-17-2009, 07:03 PM | #8 |
Rock Stacker Join Date: Feb 2009 Location: Phelan
I have been running a Hitec 5645 with the losi lipo for a while. I did a zero ackerman mod, i run the HR wider hexes with the proline titus wheels and flat irons and my tires rub the servo and the lipo. I moved the lipo to the front upper links. heres a few pics to help eexlpian. |
07-17-2009, 11:48 PM | #9 |
That looks nice man! I might try to make a plate like that. I still run the Losi crawlers so I might not run into clearance issues...And I also have the longer hex nuts so that should help. Thanks for posting the pics.
07-18-2009, 07:33 PM | #10 |
Rock Stacker Join Date: Jan 2009 Location: nor-cal
I also made my own plate. |
07-18-2009, 10:45 PM | #11 |
Ya that looks good. |
