07-19-2009, 06:08 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
| So, I guess its my turn
Well, my rear axle finally started the dreaded "popping" noise. I pulled it apart and it seems as tho the pinion and ring gear are not meshing properly... I shimmed the pinion, and it did not help... Any ideas? |
07-19-2009, 07:00 PM | #2 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Sounds like it's already to late. Once it starts popping it's usually done. Mine started popping as well. I couldn't tell from which axle. It happened more whenever turing, so I assumed it was from the front. Once I had it down I noticed the pinion was worn out. The ring gear wear patterned look as if it the pinion depth height was off but the wear on the pinion looked as if the back lash was off. So I've got some on order. Once they arive I'll paint it and check the pattern.
07-19-2009, 07:12 PM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Replacing just the gears may not fix it. My rear did it, replaced the gears and it got better but did not go away fully, then it eventually got so bad it wouldnt climb pretty much. Replaced the axle housing, and new gear set and all is well. The problem is the axle housing starts to flex under load allowing the gearset to unmesh and pop. Buy a bag of axle housings and replace em. they are cheap and make a world of difference. |
07-19-2009, 08:09 PM | #4 | |
Quarry Creeper Join Date: Oct 2008 Location: Crawlin' in NorCal!
07-19-2009, 08:57 PM | #5 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
I found out awhile ago it was the housing flexing. So instead of buying them all the time, the cheapest and effective fix is to extend a screw all the way through the case with a nut securing it. I have one in the pic below and another on the opposite hole. |
07-20-2009, 12:27 AM | #6 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| I did all 4 x 2
07-20-2009, 08:00 AM | #7 |
Yep, nutting and bolting it together seems to be the best bet... I'll be doing that, thanks for the tips |
